1jtml65p1jt220604
Hoyt94
88 comanche pioneer
Image, if available
Engine / Trans / Transfercase / Front axle / Rear axle / Wheelbase
Build date: (its on the driverside door sticker, in the form of month and year)
Current Location: northern Michigan
Status: Is it still on the road.
*X8 SEATS - CLOTH LOW-BACK BUCKET
-H9
3LY
ADL PACKAGE - 4X4 PROTECTION
AGJ Driver Assistance Group
APA MONOTONE PAINT PACKAGE
BCQ Battery - 750 Amp Maintenance Free
CAC BUCKET SEAT - LO BK
CGW Air Bags - Front, Next Generation**
CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ
CUF FULL LENGTH FRONT CONSOLE
DDQ Transmission - 5-Speed Manual
DSA LIMITED SLIP DIFFERENTIAL
DTA
ERB ENGINE - 4.0L I6 MPI GAS
GAC ALL WINDOWS - TINTED GLASS
GEC Window - Left Side, Front, Sliding
GFD SLIDING RR WINDOW
GTZ MIRRORS - MANUAL REMOTE
HAA AIR CONDITIONING - FRONT
JFH TACHOMETER - MECH
JGB Clock - Digital
JHA WINDSHIELD WIPERS - DELUXE
JJA CIGAR LIGHTER - FRT COMP
K60 BODY SIDE MOLDINGS - VINYL
LAP FUEL ECONOMY SHIFT INDICATOR LIGHT
LMA HALOGEN HEADLAMPS
MBJ Bumper - Front, Black
MDA FRT LICENSE PLATE ATTACH REQUIRED
NAE EMISS CONTROL TESTING &&&& LABEL
NFA TANK - 20 GAL FUEL
NHM AUTO SPEED CONTROL
NHQ Transmission Heater
NMB ENGINE COOLING - STANDARD DUTY
PWB
QWB
RAF Radio - AM/FM Cassette
SBA POWER STEERING
SCE STRG WHL - EURO/SPORT TYPE
SUA TILT STEERING COLUMN
TBB CONVENTIONAL SPARE TIRE
WJD
WHEELS - 15 X 7.0 STYLED STEEL
Build Date 6/2/88
Body Model JM62
  On 4/9/2020 at 1:49 AM, eaglescout526 said:
Judging by his build date with the 4.0L he probably has the BA10/5. As far as gear ratio, there should be a metal tag on the diff cover with a PN and the ratio.
Expand
Agreed and I'm guessing 3.07 for the ratio. Unless someone has swapped tranny's already and or the gears.
  On 4/9/2020 at 1:42 AM, Hoyt94 said:
What manual do I have and what gear ration is in the diffs?
Expand
the stock transmission would have been a Peugeot BA-10/5
axle ratio would have been 3.07
but lots of things can happen in 3 decades so you'll want to check and verify that.  :L:  the case for the Peugeot splits into a left and right half (the later AX-15 has a front and rear half).  gear ratio can be checked by jacking up one rear tire and spinning it around exactly twice while you count the times the driveshaft rotates.  If the driveshaft rotates about 3 and a half times, it's a 3.55 ratio.  if it spins around a bit over 4 times it's 4.10.  etc.  Their aren't infinite ratios.  the common ones you might find in the various Jeeps back then are: 3.07, 3.55, 3.73, 4.10
  • 10 months later...
  • 1 year later...
