Hoyt94 Posted April 6, 2020 Share Posted April 6, 2020 88 comanche pioneer Image, if available Engine / Trans / Transfercase / Front axle / Rear axle / Wheelbase Build date: (its on the driverside door sticker, in the form of month and year) Current Location: northern Michigan Status: Is it still on the road. Link to comment Share on other sites More sharing options...
JMO413 Posted April 6, 2020 Share Posted April 6, 2020 *X8 SEATS - CLOTH LOW-BACK BUCKET -H9 3LY ADL PACKAGE - 4X4 PROTECTION AGJ Driver Assistance Group APA MONOTONE PAINT PACKAGE BCQ Battery - 750 Amp Maintenance Free CAC BUCKET SEAT - LO BK CGW Air Bags - Front, Next Generation** CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ CUF FULL LENGTH FRONT CONSOLE DDQ Transmission - 5-Speed Manual DSA LIMITED SLIP DIFFERENTIAL DTA ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GEC Window - Left Side, Front, Sliding GFD SLIDING RR WINDOW GTZ MIRRORS - MANUAL REMOTE HAA AIR CONDITIONING - FRONT JFH TACHOMETER - MECH JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MOLDINGS - VINYL LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAE EMISS CONTROL TESTING &&&& LABEL NFA TANK - 20 GAL FUEL NHM AUTO SPEED CONTROL NHQ Transmission Heater NMB ENGINE COOLING - STANDARD DUTY PWB QWB RAF Radio - AM/FM Cassette SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE SUA TILT STEERING COLUMN TBB CONVENTIONAL SPARE TIRE WJD WHEELS - 15 X 7.0 STYLED STEEL Build Date 6/2/88 Body Model JM62 Link to comment Share on other sites More sharing options...
Pete M Posted April 7, 2020 Share Posted April 7, 2020 we really do need to figure out what that airbag code used to be. Link to comment Share on other sites More sharing options...
Hoyt94 Posted April 9, 2020 Author Share Posted April 9, 2020 What manual do I have and what gear ration is in the diffs? Link to comment Share on other sites More sharing options...
JMO413 Posted April 9, 2020 Share Posted April 9, 2020 1 minute ago, Hoyt94 said: What manual do I have and what gear ration is in the diffs? Sorry you will have to check both of those yourself. The early build sheets are not the best by any means. Link to comment Share on other sites More sharing options...
eaglescout526 Posted April 9, 2020 Share Posted April 9, 2020 Judging by his build date with the 4.0L he probably has the BA10/5. As far as gear ratio, there should be a metal tag on the diff cover with a PN and the ratio. Link to comment Share on other sites More sharing options...
JMO413 Posted April 9, 2020 Share Posted April 9, 2020 13 minutes ago, eaglescout526 said: Judging by his build date with the 4.0L he probably has the BA10/5. As far as gear ratio, there should be a metal tag on the diff cover with a PN and the ratio. Agreed and I'm guessing 3.07 for the ratio. Unless someone has swapped tranny's already and or the gears. Link to comment Share on other sites More sharing options...
Pete M Posted April 9, 2020 Share Posted April 9, 2020 1 hour ago, Hoyt94 said: What manual do I have and what gear ration is in the diffs? the stock transmission would have been a Peugeot BA-10/5 axle ratio would have been 3.07 but lots of things can happen in 3 decades so you'll want to check and verify that. the case for the Peugeot splits into a left and right half (the later AX-15 has a front and rear half). gear ratio can be checked by jacking up one rear tire and spinning it around exactly twice while you count the times the driveshaft rotates. If the driveshaft rotates about 3 and a half times, it's a 3.55 ratio. if it spins around a bit over 4 times it's 4.10. etc. Their aren't infinite ratios. the common ones you might find in the various Jeeps back then are: 3.07, 3.55, 3.73, 4.10 Link to comment Share on other sites More sharing options...
Hoyt94 Posted April 9, 2020 Author Share Posted April 9, 2020 I have identified the rear axel to be a dana 44 which I was pretty happy about and also has a factory Lsd . Link to comment Share on other sites More sharing options...
Pete M Posted April 9, 2020 Share Posted April 9, 2020 1 minute ago, Hoyt94 said: I have identified the rear axel to be a dana 44 which I was pretty happy about and also has a factory Lsd . if it has a limited slip, you'll need to jack up both rear tires and spin them around once. Link to comment Share on other sites More sharing options...
Hoyt94 Posted April 9, 2020 Author Share Posted April 9, 2020 Sounds good ill get some pictures of the old girl soon Link to comment Share on other sites More sharing options...
jdog Posted February 28, 2021 Share Posted February 28, 2021 Selling Dealer: BUERGE CHRYSLER JEEP DODGE RAM West Los Angeles, CA Link to comment Share on other sites More sharing options...
Hoyt94 Posted March 31, 2022 Author Share Posted March 31, 2022 A bit of progress has been made 👌 Need a have a drive shaft made and install the sye. Link to comment Share on other sites More sharing options...
Pete M Posted March 31, 2022 Share Posted March 31, 2022 Link to comment Share on other sites More sharing options...
