Renix Ignition coil.
Hi .
Bought a Renix ignition coil/modul from the junkyard. from a  Renault 5 early 1990 ich.
OEM Renix :L: works great. 20
It has a cable whit a thingy on it, could it be a radio capacitor??
Should it be connected to ground ?
The connector on coil are marked whit +
works great without it, but curious about what it has for function
None of us Renix guys have probably never ever seen anything plugged in there. We do know(Those who know who they are) that if you plug in the underhood light power plug, the entire system will turn on but not crank or start but would keep everything running when you turn off the truck.
:laugh: how lucky I am to have a lamp for that connector..... the one for crusecontrol is availabe...:brows:
Hi Ωhm ! :)) . I think i leave the thingy unconnected ... now that i got the Comanche is running  :L:
The local sparepart store price for the Ignition modul is 300 dollars :crazy: and probably noname made in China!
Eaglescout.....  Look for Renaults :))
8 minutes ago, Kjell said:
Look for Renaults
Yeahhhhh I have never seen an American Renault in my life and probably never will. When the U.S. did cash for clunkers, people probably got rid of them as soon as they could. Much like how we can't find many Renix era Jeeps any more.
Hard to find Renix Jeeps here in Sweden to .  There should be  Renix parts in older Volvos ....:brows::))
On 4/5/2020 at 4:48 PM, cruiser54 said:
The Renix system was widely used in Europe
Hi Cruiser54 !
Thanks for all the info you made available !!  Great job, has helped alot!:L:
Seen Renix parts in Volvos and Renaults .. Bendix parts "same s**t but different":D ...are everywhere.
Here are a different animal ,Vac ignition adjustment ?? Hot Rod parts! :brows:
