1J7FT36L4KL554872
MLT Lulu
Bought off CL a few days ago. Came from Hawaii, but haven't found the rust yet. Owners said the lived inland, saving it from the salt.
This is my first Jeep anything, (though i had a 77 hornet years ago) and as a Datsun guy, it sure is nice having a 4.0 instead of 2.0.
Had it towed home, put in a batt and an alt. Fires right up. Nor bad for 700.
There's one thing that's been bugging me. All other examples of these stripes on the sides end with the word pioneer by the tailgate. Mine doesn't. So... Base model?
I don't know all the details, but....
4.0 liter
Auto trans
2wd
Buckets
CUP HOLDERS!
And pics.....
Really just needed a little truck. Only plans are fix a couple of leaks, figure or why the dash lights don't work, and what's draining the battery. Oh, and i have the floppy steering column issue.
That said, if i had all the time and money I'd like to put in XJ buckets, wing windows,  and a roll bar or headache rack. If i make it thru all that, maybe convert to 4x4. I'll probably paint over thre stripes with flat black to match the bumpers.
No. Those are PIONEER stripes. Someone at some point removed the pioneer from the truck shortly after they got it as where the letters go would be better paint and not equally faded paint. That being said, here is your 90% accurate info:
*X8 Cloth Low-Back Bucket Seats
-YY
172 Zone 72-Portland
1AA U.S. Dealer Retail
5AM Largo Tracking
ADA Light Group
ADB Protection Group
AHL Heavy Duty Insulation Group
APA Monotone Paint
BAQ 61 AMP ALTERNATOR
BCX Open
BGA Power Front Disc/Rear Drum Brakes
BJA STD DUTY FRT DISC BRAKES
BKP 10x2.5 Rear Drum Brakes
CAC Low Back Bucket Seats
CDB Reclining Front Seats
CKA Carpets - Floor and Cargo Area
CLA Front Floor Mats
CSR Passenger Assist Handles
CUF Full Length Floor Console
DGB All 4-Speed Automatic Transmissions
DGS 4-Speed Automatic AW4 Transmission
DHA Lock-Up Torque Converter
DHS Floor Mount Automatic Shift Lever
DMD 3.55 Rear Axle Ratio
DRJ 175MM Rear Axle
EAA All Engines
EAF ALL FUEL INJECTED ENGINES-GAS
ERB ENGINE - 4.0L I6 MPI GAS
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEH Fixed Door Vent Glass
GFD Rear Sliding Window
GNA Rear View Day/Night Mirror
GNB Driver Side Illuminated Sun Visor
GRC Entire Fleet Key Alike (FREQ 7)
GUB Power Mirrors-Base
HCD Do Not Use - See HCA
HGA Hood Insulation
JAA Instrument Panel
JAY DO NOT USE - See JP, KA classes
JBD BEZEL-I/PANEL CLUSTER - BRIGHT
JCA 85 MPH Primary Speedometer
JGB Digital Clock
JHA Var Intermittent Windshield Wipers
JJA Cigar Lighter
JKB MOPAR Hood Lock
K2X STRIPE/BADGE/MOLDING/COLOR
K3T STRIPE/BADGE/MOLDING/COLOR
KKG
LAF Seat Belt Alert-Driver Seat only
LAJ Headlamps On Warning Chimes
LBB Courtesy Lamps
LBC Glove Box Lamp
LBD Ash Tray Lamp
LBE IP LED Ambient Light Pipe
LCJ DOME/READING LAMP B-PILLAR
LDH U/Hood, Removable/Rechargeable Lamp
LHD Headlamp Off Time Delay
LMA Halogen Headlamps
LPE Cargo Lamp
MB1 Black Front Bumper
MBJ Black Powder Coated Front Bumper
MCA Rear Body Color Applique
MDA Front License Plate Bracket
MFG Body Color Headlamp Bezels
MHA Black Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMK Lower Grille Surround-Painted Silver
MMP MOLDING - DOOR EDGE GUARDS
NAA Federal Emissions
NBA LIGHT DUTY CYCLE
NBK EVAP Control System
NDA Catalytic Converter
NF2 18.5 Gallon Fuel Tank
PY3 Classic Yellow Clear Coat
QY3 Classic Yellow Clear Coat
RAA All Radio Equipped Vehicles
RAF AM/FM Cassette Radio
RCD 4 Speakers
SBA Power Rack and Pinion Steering
SCE Alcantara Wrap Steering Wheel
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
SUA Tilt Steering Column
TAA All Tires
TAD HIGHWAY TREAD
TBC Compact Spare Tire
TBM Tire Carrier Winch
TPF P205/75R15 BSW All Season Tires
WJD 15X7.0 Styled Steel Wheels
XBS Pickup Box
XFA -35F Protection Anti-Freeze
YAA Build To U.S. Mkt. Specifications
YGB 1 Additional Gallons of Gas
YGG 9 Additional Gallons of Gas
Z01 Rear Spring Group I
Z1A GVW/Payload Rating
Z58 Left Front Spring Group Viii
Z78 Right Front Spring Group VIII
Build date 3/3/89
Body code TM61
  • 1 year later...
