jtdesigns Posted October 6, 2007 Share Posted October 6, 2007 Will someone identify this rear end for me please... Image Not Found And whats this little ball joint bracket looking thing bolted to the left of the pumpkin?? Image Not Found THANKS !! JT Link to comment Share on other sites More sharing options...
offroader461 Posted October 6, 2007 Share Posted October 6, 2007 D35 sorry and that ball is for an arm that connects to the load sensoning valve....it should be up above that with another ball on a swinging arm Link to comment Share on other sites More sharing options...
jtdesigns Posted October 6, 2007 Author Share Posted October 6, 2007 D35 sorry and that ball is for an arm that connects to the load sensoning valve....it should be up above that with another ball on a swinging arm D35 crap?? I don't need a darn tooting load sensoning value!!!!!!!!! .... ................................................................................................................... ummmm... DO I ????????? Link to comment Share on other sites More sharing options...
Geonovast Posted October 6, 2007 Share Posted October 6, 2007 I don't believe that's a D35, cover isn't round enough, there's a small hump on the top. Chyrcho 8.25 I believe? Link to comment Share on other sites More sharing options...
offroader461 Posted October 6, 2007 Share Posted October 6, 2007 No...most just swap in a XJ proportioning valve and eliminate it totally...i have my "arm" just wired in the up position...i lost my "arm" about 6mnths after i bought mine... The D35 isnt bad while using it carefully in stock form :roll: but anything "hard" and it may be upgrade time :D Link to comment Share on other sites More sharing options...
Geonovast Posted October 6, 2007 Share Posted October 6, 2007 Meh, I'm prolly wrong..bad angle maybe. This might help you in the future. Link to comment Share on other sites More sharing options...
jtdesigns Posted October 6, 2007 Author Share Posted October 6, 2007 No...most just swap in a XJ proportioning valve and eliminate it totally...i have my "arm" just wired in the up position...i lost my "arm" about 6mnths after i bought mine... The D35 isnt bad while using it carefully in stock form :roll: but anything "hard" and it may be upgrade time :D does that load sensor have something to do with brakes? Link to comment Share on other sites More sharing options...
jtdesigns Posted October 6, 2007 Author Share Posted October 6, 2007 Meh, I'm prolly wrong..bad angle maybe. This might help you in the future. Yeah its elliptical,, with no flat spots on the top or bottom like your picture shows.. good info though. Link to comment Share on other sites More sharing options...
Oizarod115 Posted October 6, 2007 Share Posted October 6, 2007 No...most just swap in a XJ proportioning valve and eliminate it totally...i have my "arm" just wired in the up position...i lost my "arm" about 6mnths after i bought mine... The D35 isnt bad while using it carefully in stock form :roll: but anything "hard" and it may be upgrade time :D does that load sensor have something to do with brakes? haha, yeah man... its SUPPOSED to send more pressure to the rears when loaded... most of htem don't work.. i lost my rod for about a year, then found one in a JY and picked it for 2 bucks, haven't noticed any difference. mine's probably trash Link to comment Share on other sites More sharing options...
jtdesigns Posted October 6, 2007 Author Share Posted October 6, 2007 No...most just swap in a XJ proportioning valve and eliminate it totally...i have my "arm" just wired in the up position...i lost my "arm" about 6mnths after i bought mine... The D35 isnt bad while using it carefully in stock form :roll: but anything "hard" and it may be upgrade time :D does that load sensor have something to do with brakes? haha, yeah man... its SUPPOSED to send more pressure to the rears when loaded... most of htem don't work.. i lost my rod for about a year, then found one in a JY and picked it for 2 bucks, haven't noticed any difference. mine's probably trash I'm having a problem with my brakes I wonder if this value has something to do with that... Link to comment Share on other sites More sharing options...
SomeNew Name Posted October 6, 2007 Share Posted October 6, 2007 most likely Link to comment Share on other sites More sharing options...
Eagle Posted October 6, 2007 Share Posted October 6, 2007 That's a D35. Definitely NOT a Chrysler 8-1/4". Without the connecting rod, you have no way of knowing if the load/height sensing proportioning valve is set to allow maximum or minimum pressure to the rear brakes. The procedure to recalibrate it requires, in addition to a rod of the correct length, a replacement spring that isn't available. Personally, having exploded the proportioning valve in my '88 in a panic stop, I don't trust them. I have eliminated the one that blew up (no choice!), and I will also eliminate them from all my other MJs as time permits. I can live with too much rear brakes. I cannot tolerate no rear brakes. Link to comment Share on other sites More sharing options...
carnuck Posted October 17, 2007 Share Posted October 17, 2007 One other one not on the list is the AMC Model 20, but it's round. Link to comment Share on other sites More sharing options...
