SatiricalHen Posted February 11, 2020 Share Posted February 11, 2020 Pete said I should post something about my Cherokee. Well here she is in all her beaten glory. Got it back in 2013 bone stock. Now it has a 5.5ā lift with RE coil springs, IRO leafs, Boostwerks shackles, and HD offroad no lift shackle relocation boxes. 4.6 stroker, bored TB, 4 hole injectors. XO-fab cage with extra tubes. 2x6 sliders which hold the air from my viair 444c compressors. PRP harnesses with stock Cherokee seats for now. Locked front and rear, d30 8.25, 4.56 gears front is sleeved and c gusseted. Probably missing stuff because Iāve done so much. Anyone want to know anything specific? Ā Ā Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Pete M Posted February 11, 2020 Share Posted February 11, 2020 that cage is awesome Ā what did you tie into inside the front fender? Link to comment Share on other sites More sharing options...
SatiricalHen Posted February 11, 2020 Author Share Posted February 11, 2020 that cage is awesome Ā what did you tie into inside the front fender? The slider and the firewall Ā Ā Ā Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Pete M Posted February 11, 2020 Share Posted February 11, 2020 nice tie-in spot!Ā Ā you do some great work. Link to comment Share on other sites More sharing options...
SatiricalHen Posted February 11, 2020 Author Share Posted February 11, 2020 nice tie-in spot!Ā Ā you do some great work. I donāt get the credit for the welds, I had the idea to tie it to the fire wall, to move some of the tubes and add tube to the inside, and to use the clamps on the a pillar, but I didnāt weld it. I can weld, but I had Tommy Glenn weld the cage for me. Heās a local fab guy who builds the ultra 4 chassis for Chris May. A) he knows what heās doing as heās been welding longer than Iāve been alive.B) I donāt have a welder strong enough for structural workC) if I had messed some angles up or spaced something wrong I would know about it and it would drive me crazy forever. It was very reasonable to have it all welded up, tube added and have some 2x6 added to my bumperSent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Pete M Posted February 11, 2020 Share Posted February 11, 2020 I did the same.Ā I prefer a pro doing the work that keeps me alive. Ā Link to comment Share on other sites More sharing options...
SatiricalHen Posted February 11, 2020 Author Share Posted February 11, 2020 Iāve been really wanting some tube fenders so I can keep trees away from the body and keep some mud off the windows. I also want to do some more tube work in the front. Iāve been thinking tubes under the fender and out the headerpanel to a stinger or grill hoop of sorts so if it goes over the radiator doesnāt get smashed.Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Pete M Posted February 11, 2020 Share Posted February 11, 2020 steel flares are never a bad idea Ā Link to comment Share on other sites More sharing options...
Drahcir495 Posted February 13, 2020 Share Posted February 13, 2020 Great toy. I also like the cage.Ā Ā Where did you get the Stroker done at, or did you do it yourself? And are you happy you did it? Ā Link to comment Share on other sites More sharing options...
SatiricalHen Posted February 13, 2020 Author Share Posted February 13, 2020 Great toy. I also like the cage.Ā Ā Where did you get the Stroker done at, or did you do it yourself? And are you happy you did it? Ā I had the machine work done at Dover cylinder head and I put it together. Used the clegg stage 1 stroker with stage 1 cam. Iām not super thrilled with the performance. Thereās definitely more power, but I feel like thereās something thatās not quite right. Everyone says their strokers scream and make tons of power and mine seems marginally better than the 4.0 with a blown headgasket and 200k. My Comanche has a HO head, 99+ intake, volvo injectors, and comp cam and it seems like it boogies a whole lot better. Itās also comparing apples to oranges since my Cherokee is lifted, 35s, cage, auto, and weighs 4800 lbs and my Comanche is 2wd stick shift stock height street tires. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Drahcir495 Posted February 14, 2020 Share Posted February 14, 2020 I here a lot more people say that they have issues withĀ their strokers motorsĀ than I hear itās great. I have always like to have one, but I donāt know with the lack of positiveĀ reviewsĀ . I talk to an engine rebuilder that does a lot of the 4.0s and asked him if I should do a mild cam etc when I have him rebuild it. He was I donāt think I should. Going to be more than enough with the rebuild and dependable. It was the first machine shop did not push me towards performance this and that. That had me sold.Ā I am now at a point in my life that I just want simple and reliable.Ā Link to comment Share on other sites More sharing options...
SatiricalHen Posted February 14, 2020 Author Share Posted February 14, 2020 I here a lot more people say that they have issues withĀ their strokers motorsĀ than I hear itās great. I have always like to have one, but I donāt know with the lack of positiveĀ reviewsĀ . I talk to an engine rebuilder that does a lot of the 4.0s and asked him if I should do a mild cam etc when I have him rebuild it. He was I donāt think I should. Going to be more than enough with the rebuild and dependable. It was the first machine shop did not push me towards performance this and that. That had me sold.Ā I am now at a point in my life that I just want simple and reliable.Ā The Comanche motor with a mild cam and just the ābestā of the 4.0 combo (HO head, renix block, 99+ intake). The goal was a little kick, but still super simple and super reliable. I would recommend that, I donāt know if Iād recommend a stroker yet. Still up in the air on that. I used the comp cam SK68-115-4 kit in my Comanche and Iāve had 10,000 trouble free miles (at least cam related, had some Renix electrical stuff but thatās to be expected). Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
plabruse Posted February 20, 2020 Share Posted February 20, 2020 Nice rig! Link to comment Share on other sites More sharing options...
SatiricalHen Posted February 23, 2020 Author Share Posted February 23, 2020 Added some quarter panel armor and a sub yesterday Ā Still waiting on the reverse lights which are on back order. Ā Sent from my iPhone using Tapatalk Ā Link to comment Share on other sites More sharing options...
Pete M Posted February 23, 2020 Share Posted February 23, 2020 Love it Ā Ā is the white stripe down the middle of the brake lights a backup light?Ā Ā don't forget to add a grill guard to the sub. Ā I know guys that have lost a sub from items rolling around in their Jeep.Ā Ā Link to comment Share on other sites More sharing options...
SatiricalHen Posted February 23, 2020 Author Share Posted February 23, 2020 Love it Ā Ā is the white stripe down the middle of the brake lights a backup light?Ā Ā don't forget to add a grill guard to the sub. Ā I know guys that have lost a sub from items rolling around in their Jeep.Ā Ā I keep everything tightly strapped down in my Cherokee. I added some beefy tie downs to secure the spare tire and axle shafts because I know what can happen when things become projectiles. Iād like to put a guard on it, but havenāt found anything that fits well yet. Apparently this sub is on the larger side of 8ā subs. Also, the strip is the turn signal. The open holes are reverse lights Iām waiting on. If I could do it again I would go with a different brand with more generic cut outs. There is only one place I can find the 2.5ā flange mount round light required for the circle in the back of the armor which they say you can install either turn signal or reverse lights in. I opted for turn signal built into the oval and 2.5ā reverse lights. Another company Iāve seen uses flush mount pods for their reverse lights and I feel that would be a much better option, but itās too late now. It looks good and Iāll work, just more frustration than I was expecting trying to find what I wanted. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Pete M Posted February 23, 2020 Share Posted February 23, 2020 ahhh. Ā the ones I've seen had built in reverse and then the red flashed.Ā good to know there are other options available.Ā Ā Link to comment Share on other sites More sharing options...
SatiricalHen Posted February 23, 2020 Author Share Posted February 23, 2020 ahhh. Ā the ones I've seen had built in reverse and then the red flashed.Ā good to know there are other options available.Ā Ā I probably should have done red with the reverse for the oval and the a 2.5ā amber as it was not on back order when I placed my order, but I thought I would like the turn in the oval better. Oh well weāre here now and it looks good so far. Hopefully the lights hold up well and I can focus on other things. Found the ad for the lights I ended up running. Next on the list is relocating the CB antenna as the mount shared the tail light bolt before and this armor gets in the way. I have an idea of what I want to do and I think itāll turn out pretty nifty. Just need to get the time to actually do it. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
KickināChicken Posted February 27, 2020 Share Posted February 27, 2020 On 2/23/2020 at 10:37 AM, SatiricalHen said: Added some quarter panel armor and a sub yesterday Ā Still waiting on the reverse lights which are on back order. Ā Sent from my iPhone using Tapatalk Ā Love that quarter panel armor. I need something like that for my FZJ80.Ā Link to comment Share on other sites More sharing options...
SatiricalHen Posted February 27, 2020 Author Share Posted February 27, 2020 Love that quarter panel armor. I need something like that for my FZJ80.Ā Thereās a guy that makes it, itās just a whole lot more expensive. Iāll have to ask my buddy who makes it. He had an 80 till he blew it up. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
SatiricalHen Posted February 27, 2020 Author Share Posted February 27, 2020 Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
SatiricalHen Posted March 2, 2020 Author Share Posted March 2, 2020 Kind of hard to see, but I got my CB antenna installed. Removed the factory radio antenna and use its location. For some reason Iām having trouble getting the SWR down. Itās currently a little over 3, which is not good. The mount is grounded, the coax has continuity on both the hot and ground, but no shorts. Screwed the coax into the antenna and the antenna has continuity with the other end of the coax and again not shorts to ground. Above 3 on channel 1 and 40. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
SatiricalHen Posted March 9, 2020 Author Share Posted March 9, 2020 Tried a Wilson 2000 trucker on it and it got tbe SWR lower, but itās right under 3, so still not great. There are not shorts in the coax and thereās continuity where there should be. Iām thinking it may just not be great quality or something. Iāve never had much issue getting a low SWR before. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
MiNi Beast Posted April 12, 2020 Share Posted April 12, 2020 legitimate Ā Link to comment Share on other sites More sharing options...
SatiricalHen Posted June 8, 2020 Author Share Posted June 8, 2020 Well the trucker didnāt last, out a firestik on it and thatās what itās going to have. Anyway now that thatās concluded. It runs like crap and sounds terrible. I canāt figure out the issue and itās been parked for months. Finally put some spark plugs back in it to make a video of the sound. If anyone has any ideas let me know. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
