Engine shut off while driving
My engine shut off while driving the other day. The oil and battery lights both appeared to be on a few minutes before this occurred. Anyone have any thoughts on this?
Reading online it seems like I might need a new oil sender- but not sure if that would cause the engine to actually shut off.
I don't understand this delay. Seems to me, engine is SHUT OFF when both of those lamps lit. That's what they do with KEY ON, ENGINE OFF, ENGINE STUMBLE maybe.
Sounds similar to an issue I had many years ago.  While driving, I would loose all power: engine, lights, everything.  Sometimes, it would come back on; other times, i would have to pull over and restart the engine.  Then one day it died and would not restart.  I had power - lights, gauges, and cranking- but it would not fire.  Turned out to be the CPS.
Before you throw parts at it, test the CPS.  See Cruiser's Tips #7.  Also, see CPS Testing at Lunghd.com.
Also, give us info about your MJ: Year, engine, transmission, 2 or 4 wd, major modifications, etc.
