*X1 TRIM STYLE X1 - CLOTH BENCH
-H9
143 Zone 43-Pittsburgh
1AA U.S. Dealer Retail
5KK First American Title Insurance CO.
ALA SE Decor Group
ALK Italia Package
APA Monotone Paint
BAQ 61 AMP ALTERNATOR
BCX Nickel Metal Hydride Battery
BGA Power Front Disc/Rear Drum Brakes
CBA Straight Back Bench Seat
CKJ Black Vinyl Floor Covering
CSR Passenger Assist Handles
CUM Mini Floor Console
DBB All Manual Transmissions
DCK 4SPD MANUAL TRANS - AISIN SEIKI
DMD 3.55 Rear Axle Ratio
DRJ 175MM Rear Axle
EPD ENGINE - 2.5L I4 TBI GAS
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEH Fixed Door Vent Glass
GNA Rear View Day/Night Mirror
GRV Left Manual Mirror
GUA Open
HCD Do Not Use - See HCA
HW1
JAZ DO NOT USE - See JP, KA classes
JCA 85 MPH Primary Speedometer
JJA Cigar Lighter
K3Z STRIPE/BADGE/MOLDING/COLOR
KDD
LAP Shift Indicator Warning Lamp
LBC Glove Box Lamp
LCJ DOME/READING LAMP B-PILLAR
LMA Halogen Headlamps
MB1 Black Front Bumper
MBJ Black Powder Coated Front Bumper
MDA Front License Plate Bracket
MFF Black Grille
MHB Bright Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMJ DRIP TROUGH MOLDINGS - TYPE I
NAA Federal Emissions
NBK EVAP Control System
NF2 18.5 Gallon Fuel Tank
PW7 Bright White Clear Coat
QW7 Bright White Clear Coat
RA8 Delete Radio
SBA Power Rack and Pinion Steering
SCB Perforated Steering Whl w/Red Stitch
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
TAA All Tires
TBC Compact Spare Tire
TBM Tire Carrier Winch
TNC P195/65R15 BSW AS Touring Tires
WJK 15X6.0 Styled Steel Wheels
WLY All Steel Wheels
WMC Bright Wheel Trim Rings
XBS Pickup Box
YAA Build To U.S. Mkt. Specifications
YGE 5 Additional Gallons of Gas
Z01 Rear Spring Group I
Z1A GVW/Payload Rating
Z56 Left Front Spring Group Vi
Z75 Right Front Spring Group V
Build date 3/21/90
Body code TL61.
Looks like it left the factory with a 4 speed manual
8 minutes ago, Iron said:
That is very cool that you can do that. Thanks a lot!
take it with a grain of salt though, as Chrysler reused a lot of the letter codes.  for example, you don't have the "Italia Package" or the "SE decor group" or the nickle/metal hydride battery. :L:  those codes meant something different back in the day.
Actually I am almost certain the battery codes are right. Chrysler doesn't use that battery type anymore and usually Chryslers new battery codes mention the Amps the battery puts out.
They were, that was probably the style or type of battery used kinda like how AGM and wet batteries are what we have now. Honestly its a shot in the dark, I am by far not a battery expert by any means.
I would guess lead acid battery also. I'm also guessing that is one of the few battery codes they reused on a newer model.
  • 1 year later...
