Iron Posted January 15, 2020 Share Posted January 15, 2020 1990 2.5 short bed 2wd dana 35 all stock. Currently restoring. Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 15, 2020 Share Posted January 15, 2020 *X1 TRIM STYLE X1 - CLOTH BENCH -H9 143 Zone 43-Pittsburgh 1AA U.S. Dealer Retail 5KK First American Title Insurance CO. ALA SE Decor Group ALK Italia Package APA Monotone Paint BAQ 61 AMP ALTERNATOR BCX Nickel Metal Hydride Battery BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKJ Black Vinyl Floor Covering CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DCK 4SPD MANUAL TRANS - AISIN SEIKI DMD 3.55 Rear Axle Ratio DRJ 175MM Rear Axle EPD ENGINE - 2.5L I4 TBI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GNA Rear View Day/Night Mirror GRV Left Manual Mirror GUA Open HCD Do Not Use - See HCA HW1 JAZ DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JJA Cigar Lighter K3Z STRIPE/BADGE/MOLDING/COLOR KDD LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MOLDINGS - TYPE I NAA Federal Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank PW7 Bright White Clear Coat QW7 Bright White Clear Coat RA8 Delete Radio SBA Power Rack and Pinion Steering SCB Perforated Steering Whl w/Red Stitch SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TBC Compact Spare Tire TBM Tire Carrier Winch TNC P195/65R15 BSW AS Touring Tires WJK 15X6.0 Styled Steel Wheels WLY All Steel Wheels WMC Bright Wheel Trim Rings XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z56 Left Front Spring Group Vi Z75 Right Front Spring Group V Build date 3/21/90 Body code TL61. Looks like it left the factory with a 4 speed manual Link to comment Share on other sites More sharing options...
Iron Posted January 15, 2020 Author Share Posted January 15, 2020 That is very cool that you can do that. Thanks a lot! Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 15, 2020 Share Posted January 15, 2020 No problem! Link to comment Share on other sites More sharing options...
Pete M Posted January 15, 2020 Share Posted January 15, 2020 8 minutes ago, Iron said: That is very cool that you can do that. Thanks a lot! take it with a grain of salt though, as Chrysler reused a lot of the letter codes. for example, you don't have the "Italia Package" or the "SE decor group" or the nickle/metal hydride battery. those codes meant something different back in the day. Link to comment Share on other sites More sharing options...
Iron Posted January 15, 2020 Author Share Posted January 15, 2020 Yeah I thought that was a little odd. Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 15, 2020 Share Posted January 15, 2020 4 minutes ago, Pete M said: nickle/metal hydride battery Actually I am almost certain the battery codes are right. Chrysler doesn't use that battery type anymore and usually Chryslers new battery codes mention the Amps the battery puts out. Link to comment Share on other sites More sharing options...
Pete M Posted January 15, 2020 Share Posted January 15, 2020 pretty sure it would have had a lead acid battery? Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 15, 2020 Share Posted January 15, 2020 They were, that was probably the style or type of battery used kinda like how AGM and wet batteries are what we have now. Honestly its a shot in the dark, I am by far not a battery expert by any means. Link to comment Share on other sites More sharing options...
JMO413 Posted January 16, 2020 Share Posted January 16, 2020 I would guess lead acid battery also. I'm also guessing that is one of the few battery codes they reused on a newer model. Link to comment Share on other sites More sharing options...
jdog Posted February 10, 2021 Share Posted February 10, 2021 Selling Dealer: BALES JEEP-EAGLE INCORPORATED Jeffersonville, IN Link to comment Share on other sites More sharing options...
