eaglescout526 Posted January 2, 2020 Posted January 2, 2020 Has anyone installed the new redesigned door hinges before? I have two new sets from Chrysler and they are way different but function and look like what would be used on the 97-01 XJs But Chrysler says they are direct replacements for the old ones. Just the side that mounts to the body is more open than the old solid one.
ghetdjc320 Posted January 3, 2020 Posted January 3, 2020 Following. I haven’t tried the new style. Could you post up some pictures of what you have and the part number. I used some nos hinges for my drivers door along with the reinforcement plates from hooligans off-road. Now my passenger side needs to be done.
eaglescout526 Posted January 3, 2020 Author Posted January 3, 2020 I will now post pictures. I planned on doing so a little bit later but I have time now. Hinge and instructions. Note it’s open design.
ghetdjc320 Posted January 4, 2020 Posted January 4, 2020 Interesting design. So is it supposed to weld in place like the old one?
eaglescout526 Posted January 4, 2020 Author Posted January 4, 2020 That’s what I think but I’m baffled as Chrysler’s instructions are incredibly vague.
Jeep Driver Posted January 4, 2020 Posted January 4, 2020 If you need instructions, you are likely not the one who should be replacing the hinges.
eaglescout526 Posted January 4, 2020 Author Posted January 4, 2020 You're right Jeep Driver, I shouldn't be doing such. But like everyone else I'm cheap but willing to learn and not let anyone I don't trust touch my truck. But if you see, the new hinge is much more open in design than the old solid ones.
Strokermjcomanche Posted January 4, 2020 Posted January 4, 2020 6 hours ago, ghetdjc320 said: Interesting design. So is it supposed to weld in place like the old one? Yep , just look at a 97 + XJ for reference.
eaglescout526 Posted January 4, 2020 Author Posted January 4, 2020 Just now, Strokermjcomanche said: Yep , just look at a 97 + XJ for reference. I will have to do that.
Strokermjcomanche Posted January 4, 2020 Posted January 4, 2020 I'd have to look , but if you wanted to stay with the older style I may have some new ones . If only one hinge is bad you would only have to change one . May be be a good time to install one of those reinforcing plates too if your hinges were pulling away from the body .
eaglescout526 Posted January 4, 2020 Author Posted January 4, 2020 It looks like that only the top of the hinge meaning the weld and all is separating from the body.
Strokermjcomanche Posted January 4, 2020 Posted January 4, 2020 I'd put the reinforcement plate in and leave the rest . Once the plate is in with the hinges welded to it i don't see it going anywhere.
eaglescout526 Posted January 4, 2020 Author Posted January 4, 2020 I will have to go look at the write up again and see what all I need to do to add the plate. That doesn't look bad. Looks pretty straight forward and just weld it in place of the old hinge.
