High2by Posted December 27, 2019 Posted December 27, 2019 I just bought the truck in middle TN and that's where it will stay I reckon. I plan on turning it into my new DD. 4.0/AW4 - 2wd - column shift - SWB - Pioneer. That's about all I can say for sure. It has a Ford 8.8 in the rear and bucket seats but they aren't factory I don't think.
eaglescout526 Posted December 27, 2019 Posted December 27, 2019 *E1 Cloth Bench Seat -SA Charcoal 164 Zone 64-Memphis 1AA U.S. Dealer Retail 5AM Largo Tracking 5KM AMES Department Stores ALM Longhorn Southfork Package APA Monotone Paint BAQ 61 AMP ALTERNATOR BCX Nickel Metal Hydride Battery BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHA Lock-Up Torque Converter DHT Elec,Shift-on-the-Fly,P/Time T/Case DMD 3.55 Rear Axle Ratio DRJ 175MM Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GFD Rear Sliding Window GNA Rear View Day/Night Mirror GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HCD Do Not Use - See HCA JAA Instrument Panel JAZ DO NOT USE - See JP, KA classes JBD BEZEL-I/PANEL CLUSTER - BRIGHT JCA 85 MPH Primary Speedometer JHA Var Intermittent Windshield Wipers JJA Cigar Lighter JKB MOPAR Hood Lock K2X STRIPE/BADGE/MOLDING/COLOR K3R STRIPE/BADGE/MOLDING/COLOR KKE LAF Seat Belt Alert-Driver Seat only LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MDA Front License Plate Bracket MFG Body Color Headlamp Bezels MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF2 18.5 Gallon Fuel Tank PE4 COLORADO RED PRIMARY PAINT - HE4 QE4 COLORADO RED SECONDARY PAINT - HE4 RAA All Radio Equipped Vehicles RAB AM/FM Radio RCD 4 Speakers SBA Power Rack and Pinion Steering SCE Alcantara Wrap Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TAA All Tires TBC Compact Spare Tire TBM Tire Carrier Winch TPF P205/75R15 BSW All Season Tires WJD 15X7.0 Styled Steel Wheels XBS Pickup Box XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGG 9 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z58 Left Front Spring Group Viii Z78 Right Front Spring Group VIII Build date 9/21/88 Body code TM61
High2by Posted December 27, 2019 Author Posted December 27, 2019 Thanks for the information!!!! I didn't think the buckets were factory. After looking, I know why my speedo is so far off. The 8.8 has 4.10 gears in it. Good grief!!!! It still has the license plate bracket on the front but no sliding rear window. What is the "ALM" package?
eaglescout526 Posted December 27, 2019 Posted December 27, 2019 ALM probably was once a package during the Chrysler era but changed with time. The speedo would be off if the tire size increased. Not the gearing. It could've had a slider and it probably broke all they could afford was a solid when it was still around.
Pete M Posted December 27, 2019 Posted December 27, 2019 take that list with a grain of salt. Chrysler reused some of the letters over the years and so some things might apply to newer cars. The Mopar hood lock for example probably refers to a Wrangler and so the original meaning of JKB won't show up in the dealership computers. a change in gearing will also change the speedo since our trucks' speedo cables measure the driveshaft speed rather than wheel speed.
eaglescout526 Posted December 27, 2019 Posted December 27, 2019 32 minutes ago, Pete M said: a change in gearing will also change the speedo since our trucks' speedo cables measure the driveshaft speed rather than wheel speed. Huh. Had no idea it played a roll in that. Noted
Pete M Posted December 27, 2019 Posted December 27, 2019 Just now, eaglescout526 said: Huh. Had no idea it played a roll in that. Noted yup. the ratio changes the driveshaft's rotation speed. usually we just concern ourselves in the other direction but it works both ways.
High2by Posted December 28, 2019 Author Posted December 28, 2019 On 12/26/2019 at 6:52 PM, Pete M said: a change in gearing will also change the speedo since our trucks' speedo cables measure the driveshaft speed rather than wheel speed. This is true and since it is sitting on basically the same size diameter tire as from the factory, it's way off. I know there is a chart that shows what tooth gear to use based on tire size and gearing but I haven't even pulled the speedo gear out to see what it looks like yet. I am not as familiar with this set up since it doesn't have a transfer case in it. Is the speedo gear the same as the one that would fit in the t-case?
fiatslug87 Posted December 28, 2019 Posted December 28, 2019 Speedo gears are the same between 2WD and 4WD. Obviously yours is in the transmission tail end and should be the long shaft version.
High2by Posted December 28, 2019 Author Posted December 28, 2019 11 hours ago, fiatslug87 said: Speedo gears are the same between 2WD and 4WD. Obviously yours is in the transmission tail end and should be the long shaft version. Long shaft...that sounds bad, but that's what I wasn't sure about. Thanks!!
High2by Posted December 29, 2019 Author Posted December 29, 2019 I found this taped to the inside of the drivers door panel. It's hard to read though...
jdog Posted March 29, 2021 Posted March 29, 2021 Selling Dealer: SOUTHEAST CHRYSLER JEEP DODGE Nashville, TN
