Swampy Posted December 23, 2019 Share Posted December 23, 2019 Hey guys. I need some help. As some of you know, my mj caught on fire and I am swapping a new harness. I found a random red wire that was cut. I goes back to the starter relay, only problem is I'm not sure where it goes. The red wire meets 2 other red wires (total of 3) at a fuse-able link that goes to a green wire on the starter relay. One of the red wires has like a spade connector on it, the other seems to go to one of the bulkhead connectors for the fuse panel under the dash. I have been looking at the wiring diagram and I don't find the fuse-able link with 3 red wires Link to comment Share on other sites More sharing options...
Swampy Posted December 23, 2019 Author Share Posted December 23, 2019 I think the cut wire is supposed to go the latch relay but I'm not sure where that's at on the truck. Link to comment Share on other sites More sharing options...
Ωhm Posted December 23, 2019 Share Posted December 23, 2019 Could be Fusible Link H: Link to comment Share on other sites More sharing options...
Swampy Posted December 23, 2019 Author Share Posted December 23, 2019 4 minutes ago, Ωhm said: Could be Fusible Link H: maybe. I'm somewhat relieved if it's that one because I don't have the engine compartment lamp or fog lamps. Link to comment Share on other sites More sharing options...
Swampy Posted December 23, 2019 Author Share Posted December 23, 2019 Anyone with a manual 2.5 could post pics of there engine bay wiring. need some help find which connectors go to which plugs Link to comment Share on other sites More sharing options...
Ωhm Posted December 23, 2019 Share Posted December 23, 2019 Download: Check out pages 86 and 87. May help. Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 23, 2019 Share Posted December 23, 2019 If what Ohm posted doesn't help you, I can snap some pics tomorrow during my lunch to help you out. Link to comment Share on other sites More sharing options...
Swampy Posted December 23, 2019 Author Share Posted December 23, 2019 17 hours ago, eaglescout526 said: If what Ohm posted doesn't help you, I can snap some pics tomorrow during my lunch to help you out. Pictures always help. I am going through the power distribution on the jeep. Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 23, 2019 Share Posted December 23, 2019 Alrighty. I’ll snap some pics for ya later. Link to comment Share on other sites More sharing options...
Swampy Posted December 27, 2019 Author Share Posted December 27, 2019 On 12/23/2019 at 4:16 PM, eaglescout526 said: Alrighty. I’ll snap some pics for ya later. much appreciated Link to comment Share on other sites More sharing options...
Swampy Posted December 27, 2019 Author Share Posted December 27, 2019 I don't know what this plug is.... Also I cannot find a plug for the alternator or the oil pressure sender on this "new harness" Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 27, 2019 Share Posted December 27, 2019 Alrighty. It’s a goal to get pictures today. The holidays and such is madness. Anyways that top plug goes to a sensor on the power steering pump pipe. The oil pressure should be just a single plug with black rubber on it to protect the plug itself and the alt should be a GM looking plug that is rectangle in shape. Link to comment Share on other sites More sharing options...
Swampy Posted December 27, 2019 Author Share Posted December 27, 2019 6 minutes ago, eaglescout526 said: Alrighty. It’s a goal to get pictures today. The holidays and such is madness. Anyways that top plug goes to a sensor on the power steering pump pipe. The oil pressure should be just a single plug with black rubber on it to protect the plug itself and the alt should be a GM looking plug that is rectangle in shape. I installed power steering from a 4.0l I'll see if it has that plug that's the alternator plug and oil sender plug from my old harness. I can't find them on the new harness might just rewire them completely. Have plenty of material Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 27, 2019 Share Posted December 27, 2019 7 minutes ago, Swampy said: I installed power steering from a 4.0l I'll see if it has that plug Hmm. I don't know about the 4.0. It should be just a sensor on a pipe for power steering and not on the pump itself. I will be sure to get thorough and detailed pics for ya. Link to comment Share on other sites More sharing options...
Swampy Posted December 27, 2019 Author Share Posted December 27, 2019 As far as the alternator and oil sender go. I found the wires for the voltage gauge and the oil pressure gauge behind the gauge cluster. Can I just wire them straight to the gauge cluster? Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 27, 2019 Share Posted December 27, 2019 Don't quote me on such, Ohm would know better than me but I don't see why not. Link to comment Share on other sites More sharing options...
Ωhm Posted December 27, 2019 Share Posted December 27, 2019 Looks like your missing the Alternator Harness. Can you get it off your old harness. Look on pg 87 for C105 (Engine to Alternator). Also includes Oil Sender or Pressure Switch. Link to comment Share on other sites More sharing options...
Swampy Posted December 27, 2019 Author Share Posted December 27, 2019 No don't think I'm going to be able to get if from my old harness. using the diagrams I am remaking the connections that were needed Link to comment Share on other sites More sharing options...
Ωhm Posted December 27, 2019 Share Posted December 27, 2019 Does your new/replacement harness have C105? If so, wire to that. Link to comment Share on other sites More sharing options...
Swampy Posted December 27, 2019 Author Share Posted December 27, 2019 9 minutes ago, Ωhm said: Does your new/replacement harness have C105? If so, wire to that. It does. I found it. Thanks! Link to comment Share on other sites More sharing options...
Swampy Posted December 28, 2019 Author Share Posted December 28, 2019 Jeep is cranking but the fuel pump isnt priming. If I checked it correctly the connector by the gas tank wasn't getting power in the key on/run position. I have to check grounds, going to add fuel pump ground. open to ideas Link to comment Share on other sites More sharing options...
Ωhm Posted December 28, 2019 Share Posted December 28, 2019 Does D1_6 show B+ voltage when engine is CRANKING? Link to comment Share on other sites More sharing options...
Swampy Posted December 29, 2019 Author Share Posted December 29, 2019 23 hours ago, Ωhm said: Does D1_6 show B+ voltage when engine is CRANKING? going to check this tomorrow. I haven't had the chance today Link to comment Share on other sites More sharing options...
Swampy Posted December 29, 2019 Author Share Posted December 29, 2019 well the D1_6 shows voltage but not enough. when cranking it was at 0.58 volts... I was going to add the fuel pump ground tomorrow. but not sure what else it could be Link to comment Share on other sites More sharing options...
Ωhm Posted December 29, 2019 Share Posted December 29, 2019 D1_6 is the switched side of the fuel pump relay (fuel pump voltage). Measure voltage on the following pins: D1-5 B+ (Hot at all times) D1_2 B+ (Hot with KEY ON or engine CRANKING) Link to comment Share on other sites More sharing options...
