eaglescout526 Posted December 12, 2019 Share Posted December 12, 2019 Have any of you guys installed a set before? If so, what was done about the air dam to get the hooks through? Link to comment Share on other sites More sharing options...
fiatslug87 Posted December 12, 2019 Share Posted December 12, 2019 I cut notches into them just big enough for the hooks. Make a cardboard template once the hooks are in and trace the cutouts onto the air dam (mark a fastener or something so you can line up the template correctly), a fresh utility blade will work. You can also drill holes at the corners to terminate your cuts. Link to comment Share on other sites More sharing options...
mark corbitt Posted December 12, 2019 Share Posted December 12, 2019 Mine came with factory chrome hooks, but the dam has been"deleted" . I would like to see a factory set-up also. Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 12, 2019 Author Share Posted December 12, 2019 34 minutes ago, fiatslug87 said: I cut notches into them just big enough for the hooks. Make a cardboard template once the hooks are in and trace the cutouts onto the air dam (mark a fastener or something so you can line up the template correctly), a fresh utility blade will work. You can also drill holes at the corners to terminate your cuts. That’s what I was leaning towards doing but am hesitant. Got a pic of it just to get an idea? Anyone have a straight from the factory set up? Even an XJ pic will do. Link to comment Share on other sites More sharing options...
fiatslug87 Posted December 12, 2019 Share Posted December 12, 2019 Best I can do. Link to comment Share on other sites More sharing options...
mjben Posted December 12, 2019 Share Posted December 12, 2019 Here's a factory 97+... Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 12, 2019 Author Share Posted December 12, 2019 42 minutes ago, fiatslug87 said: Best I can do. Pretty much it looks like it needs to be an inch longer than the non hook opening. Ok. I think I can figure out how to do that. Thanks fiat! Link to comment Share on other sites More sharing options...
schardein Posted December 13, 2019 Share Posted December 13, 2019 I had the same questions you did. I eventually found some pics on the internet. I cut my own, trying to minimize the size to only what was required. I swear I took pics while doing it, but I can't find them. So I took some just now of the finished install. From what I recall, the factory cuts aren't anything fancy. Do you have the angle pieces to replace the clip nuts? I hate those darn clip nuts, they can make removing the bumper a nightmare when the break. Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 13, 2019 Author Share Posted December 13, 2019 9 minutes ago, schardein said: I had the same questions you did. I eventually found some pics on the internet. I cut my own, trying to minimize the size to only what was required. I swear I took pics while doing it, but I can't find them. So I took some just now of the finished install. From what I recall, the factory cuts aren't anything fancy. Do you have the angle pieces to replace the clip nuts? I hate those darn clip nuts, they can make removing the bumper a nightmare when the break. Yup, I have every factory piece I need to install them. Looks like what I just need to do is take on of those drill saws and just cut a circle out on the air dam. Link to comment Share on other sites More sharing options...
schardein Posted December 13, 2019 Share Posted December 13, 2019 2 minutes ago, eaglescout526 said: Yup, I have every factory piece I need to install them. Looks like what I just need to do is take on of those drill saws and just cut a circle out on the air dam. Somewhere in here there is a thread where Hornbrod did his, and if I recall correctly, that is how he did his. Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 13, 2019 Author Share Posted December 13, 2019 4 minutes ago, schardein said: Somewhere in here there is a thread where Hornbrod did his, and if I recall correctly, that is how he did his. I will have to go hunt it down. Link to comment Share on other sites More sharing options...
Eagle Posted December 13, 2019 Share Posted December 13, 2019 The factory cutout is rectangular, about 2-1/2" wide, with the lower corners rounded. It's larger than the opening shown in the photos Schardein found. Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 14, 2019 Author Share Posted December 14, 2019 I found it. Putting it here for my future reference when I figure out why some of my front end is a tad bit tweaked. Link to comment Share on other sites More sharing options...
