Metal valve cover options.
I just did the swap. I used one off a 2000 TJ. Good upgrade. Here’s some before and after pics of mine feel free to ask any questions. Make sure you grab the valve cover bolts off the donor because they are a longer than the plastic one.
d9be582de41002471fc891e159989389.jpg3a716905e9cb06e9f8cfd6a3ddd57af0.jpg41923906962bed6a16f59ef269268148.jpg
Well got everything done and put back together and she’s running. Still have to clean oil off from old vc.
Now the question is where to plumb vc lines too ??
Old vc had 2 lines 1 pcv and
1 ccv that went too metal tubing around and under the throttle body.
New aluminum valve cover has brass port on side of front and 1 pcv elbow on back of valve cover.
1. I could plumb pvc and ccv together with a tee and run to pvc elbow and plug the front brass fitting ?
2. Where previous pcv was connect to brass port on front of vc and plumb back 1 previous ccv to the new pcv elbow ?
Any comments or suggestions welcomed will be doing that tomorrow.
Kind regards
M. David (GaTnMason)
1990 Soft Top
YJ Wrangler 2.5L XJ 4cyl.
with aluminum valve cover conversion from a 92 wrangler,
31” tires back space 4” for wider base. 220,00 miles
