ghetdjc320 Posted November 4, 2019 Share Posted November 4, 2019 Looking at putting in a set of auto meter gauges in my 91 mj. I’d like to do all 6 dash gauges. Has anyone ever fabed up some sort of panel or mount for this? Link to comment Share on other sites More sharing options...
derf Posted November 4, 2019 Share Posted November 4, 2019 I've searched on XJ gauges and have seen some things. I've been looking at fabricating an aluminum piece that can go in place of the dash cluster at least, and maybe the panel to the left of the gauges. It looks like there's plenty of room to fit gauges there. I found this picture on a google search. Link to comment Share on other sites More sharing options...
derf Posted November 4, 2019 Share Posted November 4, 2019 Here's a better picture of the thing I'm looking at duplicating. I'd organize the gauges a little better than these are, more like the picture above. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted November 4, 2019 Author Share Posted November 4, 2019 Thanks for the ideas! I’ll check into building a custom piece Link to comment Share on other sites More sharing options...
JustEmptyEveryPocket Posted November 5, 2019 Share Posted November 5, 2019 Why not put in a factory gauge cluster with everything? Link to comment Share on other sites More sharing options...
Limeyjeeper Posted November 5, 2019 Share Posted November 5, 2019 I have been looking at the Auto Meter Custom gauges. Some pretty sweet combinations. https://www.ampcustomshop.com Link to comment Share on other sites More sharing options...
JrMJ89 Posted November 5, 2019 Share Posted November 5, 2019 Here's a better picture of the thing I'm looking at duplicating. I'd organize the gauges a little better than these are, more like the picture above. Would like same thing with diff config. For gauges Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
schardein Posted November 5, 2019 Share Posted November 5, 2019 Personally, I don't think anything looks as good as the factory gauges. But if planning to go custom/aftermarket, I would take a look at Speedhut. I have a set of their gauges in my CJ-7 and they are awesome. The speedo runs off GPS, no need for a speedometer cable or to calibrate it for different gears or tires. Has the capability to run off a computer speed signal if desired. Link to comment Share on other sites More sharing options...
derf Posted November 5, 2019 Share Posted November 5, 2019 The reason I'm looking into it is that I'd like to have more gauges than the factory offers. I can pack a speedometer/tach combo and a matching full size gauge with the 4 basics. That leaves me room for 4 more gauges that I can add for whatever. I can add a transmission temp gauge, an air pressure gauge for my OBA system, or even pressure gauges on the air lockers. Oil temp, which is usually not far off from water temp, is something useful to monitor. An air/fuel gauge is helpful as well. A fuel pressure gauge would help with diagnostics. If I do a diesel swap, having a boost gauge and EGT is essential in my book, The Cummins R2.8 comes with its own smaller gauge for engine status that I would need to fit. Sure, I could run the full factory dash and then find pods for the other gauges. But a well designed dash replacement with aftermarket gauges is cleaner and everything is all right there in one place. I don't have to look around the cabin to look at all of the gauges. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted November 5, 2019 Author Share Posted November 5, 2019 5 hours ago, derf said: The reason I'm looking into it is that I'd like to have more gauges than the factory offers. I can pack a speedometer/tach combo and a matching full size gauge with the 4 basics. That leaves me room for 4 more gauges that I can add for whatever. I can add a transmission temp gauge, an air pressure gauge for my OBA system, or even pressure gauges on the air lockers. Oil temp, which is usually not far off from water temp, is something useful to monitor. An air/fuel gauge is helpful as well. A fuel pressure gauge would help with diagnostics. If I do a diesel swap, having a boost gauge and EGT is essential in my book, The Cummins R2.8 comes with its own smaller gauge for engine status that I would need to fit. Sure, I could run the full factory dash and then find pods for the other gauges. But a well designed dash replacement with aftermarket gauges is cleaner and everything is all right there in one place. I don't have to look around the cabin to look at all of the gauges. that pretty much sums up why I want to do custom gauges as well. That and accuracy Link to comment Share on other sites More sharing options...
JrMJ89 Posted November 6, 2019 Share Posted November 6, 2019 Would like to start my gauges @$$ wellSent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
