Manche757 Posted October 8, 2019 Share Posted October 8, 2019 Who has a magic bullet for door hinges making a #$!&^@ noise when closing. Lubing last 10 days. New hinges? Link to comment Share on other sites More sharing options...
Pete M Posted October 8, 2019 Share Posted October 8, 2019 door pop? are the doors contacting the fenders? Link to comment Share on other sites More sharing options...
Manche757 Posted October 8, 2019 Author Share Posted October 8, 2019 No. Door stuck when closing. Snaps or pops to free it. Typical old car thing Link to comment Share on other sites More sharing options...
mark corbitt Posted October 8, 2019 Share Posted October 8, 2019 My passenger door was "popping" and I noticed the "pin" in the part that holds the door open had been replaced with a bolt. When I replaced the bolt with the proper pin, it fixed it. Link to comment Share on other sites More sharing options...
mjeff87 Posted October 9, 2019 Share Posted October 9, 2019 Yeah, the actual OEM part is a split roll pin with a bunch of funky profiles. If yours is worn, or replaced with anything else it could be causing the pop. Link to comment Share on other sites More sharing options...
AZJeff Posted October 9, 2019 Share Posted October 9, 2019 The door checks themselves will wear out on XJ/MJ vehicles and start making poppin noises. The fix is a new door check, and probably a new bracket where the check arm attaches to the “A” pillar. New door checks can be had from several sources. Link to comment Share on other sites More sharing options...
Manche757 Posted October 9, 2019 Author Share Posted October 9, 2019 Anyone have a part number for the door check? 89MJ, 4.0, 5 speed Link to comment Share on other sites More sharing options...
AZJeff Posted October 10, 2019 Share Posted October 10, 2019 9 hours ago, Manche757 said: Anyone have a part number for the door check? 89MJ, 4.0, 5 speed They are all the same for MJ and XJ vehicle front doors. It’s a Dorman 924-148 for the check. It’s on Amazon. several makers offer the bracket and pin on Amazon as well Link to comment Share on other sites More sharing options...
Manche757 Posted October 10, 2019 Author Share Posted October 10, 2019 Thanks AZ, will look for those Link to comment Share on other sites More sharing options...
ghetdjc320 Posted October 10, 2019 Share Posted October 10, 2019 I got new oem hinges and check stops from team Cherokee and installed them along with some hinge reinforcements from hoolihans off-road. Problem solved, no more popping. My popping was coming from the door dropping when opened. Had to reinforce my striker too with a large fender washer. It turned out very good though. Link to comment Share on other sites More sharing options...
