yxmj Posted September 13, 2019 Share Posted September 13, 2019 On the tech page I was commented on because I once diverted my windshield washer spray to cool a CPS to make it home…. That’s nothing…..It got me thinking that since my youth for what ever reason I had found other uses for the windshield washing system 3 other uses for your windshield washer spray 1) A bit of extra hose to each of the rear wheel wells of a 69 Chevelle so it dumps out in front of and on the rear wheels…..fill the bottle with Bleach…..When you pull up to the Stop light hit the button 3 times……Punch it and you have the best stop light burn out ever. 2) Get a new reservoir bottle……Run the hose into the cab under the dash……Fill the bottle with Jack and Coke……Now when they search you going into the drive in Movie (if they still had them) you are not caught with booze…..but you can impress the girls by having Jack and Coke on ”Tap” 3) This on requires access to your buddies truck for a bit of time…..Run the hose and conceal it so it ends up under the steering column pointing at the drivers crotch……Run a wire lead from the brake light wire to the washer pump……..Tell your buddy it is 3 for 1 beer night at the bar and you will meet him there…..priceless when he gets out of the truck Link to comment Share on other sites More sharing options...
Eagle Posted September 13, 2019 Share Posted September 13, 2019 When I was in high school I knew a guy who ran his washer hose back to the tailpipe. When he hit the "wash" button it sprayed onto the hot exhaust, creating a cloud of steam behind him as he went down the road. Link to comment Share on other sites More sharing options...
Deleted Posted September 13, 2019 Share Posted September 13, 2019 I can imagine the looks on faces of the people around you as you proceeded to fill your washer fluid reservoir with coke Link to comment Share on other sites More sharing options...
gogmorgo Posted September 13, 2019 Share Posted September 13, 2019 I once put some cheap vodka in my Lada's washer fluid bottle for the lols. It doesn't really clean the windshield that well. It wasn't awful, just kinda streaky. On 9/13/2019 at 9:49 PM, Pirate_Staz said: I can imagine the looks on faces of the people around you as you proceeded to fill your washer fluid reservoir with coke Expand I've also debated trying to use the washer fluid reservoir as an fuel dispenser for a carbed truck that had a mechanical fuel pump fail just to get it back onto a highway (at least into cell service), but just as we decided to go for it someone happened to drive by and we caught a ride to a parts store and back. Link to comment Share on other sites More sharing options...
mjben Posted September 14, 2019 Share Posted September 14, 2019 The last Cherokee I had, the rear wiper motor was shot so I pulled off the hose from the nozzle to the gate, leaving just the nipple sticking out. Was fun to squirt friends behind me at stop lights and on the trail. Also had a buddy with a 55 Chevy gasser wagon with a moon tank on the front. Just for looks. We decided to put a ball valve on the bottom and fill it up with the beverage of choice. Was fun seeing people reactions at cruise nights when we poured a drink from the "fuel" tank... Link to comment Share on other sites More sharing options...
schardein Posted September 14, 2019 Share Posted September 14, 2019 Saw this one at college (Automotive Technology) Fill the bottle with trans fluid. Run the hose to a vacuum fitting on the base of the carb. Hit the button get the biggest smoke screen you've ever seen. Link to comment Share on other sites More sharing options...
