Ωhm Posted August 24, 2019 Share Posted August 24, 2019 The ECU (KEY ON) controls the Fuel Pump Relay and NO, I don't think the short is before the relay. Need visual inspections of the following: Disconnect Bulkhead C100 (Engine Harness to Instrument Panel Harness). Backside of Fuse Panel. Both ECU connectors. Was this vehicle ever driven underwater? Link to comment Share on other sites More sharing options...
Cheapamanche Posted August 24, 2019 Author Share Posted August 24, 2019 Geezer probably. The last owner, garaged for 15 years, was a high school student. The C101 is very clean and so are the ecu connectors. They look brand new clean. If you really want to see them or suspect them I can send some pics tomorrow. I have the bbq going right now. Hungry kids. Link to comment Share on other sites More sharing options...
Ωhm Posted August 24, 2019 Share Posted August 24, 2019 No pics necessary if connectors look clean, no popped out wires touching other wires or strange growth on the terminals. Link to comment Share on other sites More sharing options...
Cheapamanche Posted August 25, 2019 Author Share Posted August 25, 2019 No nothing that causes alarm. Aside from my driver side front running light always being on and my front blinkers sometimes working, I'm just going to let good enough be for the time being. I don't have the time or funds to fix anything right now. It's my work truck and I need it Monday through friday and with three young daughters they take up my weekend time right now. I just discovered my injectors are leaking and this needs to take top priority at the moment. I don't need a fire. Link to comment Share on other sites More sharing options...
Ωhm Posted August 25, 2019 Share Posted August 25, 2019 Wish we could have put a handle on your electrical problems better than what we did. Check C102 (Engine Harness to Front Lighting Harness). This connector is a known problem. Link to comment Share on other sites More sharing options...
Cheapamanche Posted August 27, 2019 Author Share Posted August 27, 2019 I looked for this harness. I couldn't find it. I pulled the headlamp out and still no luck. You have been a tremendous help! Got the 4 hole injectors in. They fixed my leak and my stumbling idle. Link to comment Share on other sites More sharing options...
Cheapamanche Posted August 27, 2019 Author Share Posted August 27, 2019 In fact, I know it's part of my issue. If I jiggle the wires to my driver blinker it shorts out. Link to comment Share on other sites More sharing options...
jdog Posted August 28, 2019 Share Posted August 28, 2019 I looked for this harness. I couldn't find it. I pulled the headlamp out and still no luck. You have been a tremendous help! Got the 4 hole injectors in. They fixed my leak and my stumbling idle. Sometimes it's easier to pull the air box to find itStock 1988 swb 4.0 ax15 np 231. Link to comment Share on other sites More sharing options...
Cheapamanche Posted August 29, 2019 Author Share Posted August 29, 2019 Will do thanks Link to comment Share on other sites More sharing options...
