tprman Posted June 20, 2019 Share Posted June 20, 2019 I am wanting to install a after market temperature gauge on my 88 MJ 4.0. I have noticed the factory temperature gauge hole on the back of the engine is to small to screw in the new gauge sensor. Where is a good place to mount the sensor on the engine. I would like to use the same hole as the old sensor on the back of the engine but I have not yet found a after market senor that will work.. any suggestions that might work . Thanks. Link to comment Share on other sites More sharing options...
omega_rugal Posted June 21, 2019 Share Posted June 21, 2019 thermostat housing... Link to comment Share on other sites More sharing options...
tprman Posted June 21, 2019 Author Share Posted June 21, 2019 I thought about that. But I’d have to buy a new thermostat housing . Mine does not have a place for Temp gauge. Link to comment Share on other sites More sharing options...
Ωhm Posted June 21, 2019 Share Posted June 21, 2019 Block coolant drain plug. Near the ECT sensor. Link to comment Share on other sites More sharing options...
tprman Posted June 21, 2019 Author Share Posted June 21, 2019 I’ll check that out. Thanks. Link to comment Share on other sites More sharing options...
Jeep Driver Posted June 21, 2019 Share Posted June 21, 2019 1 hour ago, tprman said: I am wanting to install a after market temperature gauge on my 88 MJ 4.0. I have noticed the factory temperature gauge hole on the back of the engine is to small to screw in the new gauge sensor. Where is a good place to mount the sensor on the engine. I would like to use the same hole as the old sensor on the back of the engine but I have not yet found a after market senor that will work.. any suggestions that might work . Thanks. My Speehut sensor fits in the back of the head. What gauge/sensor are you trying to use? Link to comment Share on other sites More sharing options...
Jeep Driver Posted June 21, 2019 Share Posted June 21, 2019 41 minutes ago, tprman said: But I’d have to buy a new thermostat housing And what's wrong with buying a new one? JY for $8.00 Link to comment Share on other sites More sharing options...
tprman Posted June 21, 2019 Author Share Posted June 21, 2019 Just a standard after market gauag. But I think i May have found a thermostat housing that will work. Link to comment Share on other sites More sharing options...
DirtyComanche Posted June 21, 2019 Share Posted June 21, 2019 The factory put the sending unit there for a reason. It's the hottest part of the engine. Link to comment Share on other sites More sharing options...
omega_rugal Posted June 21, 2019 Share Posted June 21, 2019 the radiator, where you put the thermo switch for the efan... Link to comment Share on other sites More sharing options...
DirtyComanche Posted June 21, 2019 Share Posted June 21, 2019 1 hour ago, omega_rugal said: the radiator, where you put the thermo switch for the efan... That won't tell you if you're overheating from a stuck tstat. Actually, it will only tell you if things have gone nuclear hot and the cooling system is completely saturated. Link to comment Share on other sites More sharing options...
