2.5L Knock-Is this the beginning of the end?
I am looking for some guidance, opinions and recommendations, not necessarily in that order, from the wealth of knowledge that exists on this site. So my 86 2.5 has been developing a knock (no, not just a ticking) in the last couple of months, along with smoke exiting the tailpipes. I also noticed that the last time I changed the oil a few months ago, which was very black, the new oil became very dark within a few days afterwards with very little driving. This is not a DD and it currently sits more than it is driven. I have also noticed that it seems to have a lack of power from just a few months ago. I have not done all of the tests that everyone is probably thinking to themselves right now, compression test, leak down test, etc., because I haven't the tools and have not had the chance to get to it. My question is, do you think with what I have told you that this 2.5 may be worn out? The odometer reads around 168K, but I am not sure it is even the original engine. You can also see from the attached picture that these two dark circles on this piece of OSB were created when I fired it up. It was placed about 18 inches behind the tail pipes and appears to be oil spots. I will try to get a video of it running and post it if anyone thinks that will help.
Do you think I need to start looking for another 2.5, or could I be missing something else other than what I already fear is the obvious? Thanks.
You're a smart guy........you already know what to expect.
Yes, you'll get opinions based on two trains of thought here.
One will say- Do a compression test, replace your PCV valve and change your oil.....Jeeps go for 500,000 miles.
And then...........there is me. :P
Based on your own assessment you've answered your own question.
It's my assertion that you got exactly what a 2.5 was built to deliver.......good for 150K, if you took real good care of it- maybe 200K.
There are no magic tricks, it's time for a rebuild.
Also, when it's old and tired and it talks to you and tells you it's old and tired.........well, it's old and tired.
white?? blue?? black??
Looks like soot.
Yeah, your right. I pretty much know where this is heading. Guess I was just having a fleeting moment of denial.
But to reference what you said in you last line... Its Like starring in a mirror some days. Lol
86_2.5_Knocking.html
Looks like soot.
Looks kind of white to me, but could be bluish. I can't trust these eyes no more. But, it's not as heavy or thick as I expected.
I will try to post the videos I have of the engine running and tail pipe smoke tomorrow. I seem to be having a computer issue right now.
And I will pull the plugs and also do a compression test to get some numbers and confirm things. If for no other reason, maybe someone else will get something out of this too.
I recently removed the throttle bore and cleaned it, replaced a bunch of questionable vacuum hoses, cleaned up and replaced the air box and all its connections, all electrical connections pertaining to the TBI and sensors, and started on a couple of Cruisers tips. I was having stalling issues when pushing the clutch in while down shifting to slow down. Doing all that cleared up about 98% of the stalling. 100% would have been better though.
I read what people write and answer accordingly.
FWIW, I discounted the pic of soot marks.......meaningless to me.
