eaglescout526 Posted July 21, 2019 Share Posted July 21, 2019 13 minutes ago, PIKE said: Don't forget about the high altitude CPS, Mopar 53005421 Those are long gone. One dealer has one and according to the parts catalogue, its for the YJ Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted July 21, 2019 Author Share Posted July 21, 2019 5 hours ago, eaglescout526 said: Those are long gone. One dealer has one and according to the parts catalogue, its for the YJ Just picked a mopar 53005421 for $37 shipped, it does fit the Comanche. Link to comment Share on other sites More sharing options...
Russell E. Gray Posted July 21, 2019 Share Posted July 21, 2019 Good Morn: I will be chk around Mon Morn. I am down in S/E corner of N.C. out side Wilmington, small town of Rocky Point. Thanks for all the Assist. Be safe. Russ Link to comment Share on other sites More sharing options...
Jeep Driver Posted July 21, 2019 Share Posted July 21, 2019 1 hour ago, Russell E. Gray said: Good Morn: I will be chk around Mon Morn. I am down in S/E corner of N.C. out side Wilmington, small town of Rocky Point. Thanks for all the Assist. Be safe. Russ I have two Jeep dealers near me without going to Knoxville. The parts manager for one is an old-timer who is very helpful and has worked with me in the past. The other is run by young guys who flat told me they were not interested in finding parts which are not 'in the system'. Talk to the parts people.........hopefully you'll find helpful people. As a side note- I used to order through Morris 4x4 until they removed Comanche from their parts search list. I could still order by part number but I refuse, I sent them a complaint email some time ago and they never bothered to respond. You'll find that others don't bother to list the Comanche either. You'll see the XJ guys get pushed out before long. Link to comment Share on other sites More sharing options...
WahooSteeler Posted July 12, 2020 Share Posted July 12, 2020 Bringing this thread back because looks like I need a CPS. Have located the kit 83100066 and also just the CPS 33004761, any special reason to get the kit vs just the CPS? $70 more for the kit. Link to comment Share on other sites More sharing options...
eaglescout526 Posted July 12, 2020 Share Posted July 12, 2020 9 minutes ago, WahooSteeler said: Bringing this thread back because looks like I need a CPS. Have located the kit 83100066 and also just the CPS 33004761, any special reason to get the kit vs just the CPS? $70 more for the kit. The kit will directly bypass the harness and go straight into the ECU, thus eliminating any and all resistance between the CPS and the ECU. Link to comment Share on other sites More sharing options...
WahooSteeler Posted July 12, 2020 Share Posted July 12, 2020 21 minutes ago, eaglescout526 said: The kit will directly bypass the harness and go straight into the ECU, thus eliminating any and all resistance between the CPS and the ECU. Certainly seems advantageous, I guess the question then would be how hard is it to get it to the ECU and connected? Link to comment Share on other sites More sharing options...
eaglescout526 Posted July 12, 2020 Share Posted July 12, 2020 15 minutes ago, WahooSteeler said: Certainly seems advantageous, I guess the question then would be how hard is it to get it to the ECU and connected? It's simple to do but its time consuming. If you have a general know how on splicing wires and drilling a hole through to the ECU, it can be done. Luckily I picked up a couple TSB books from 88 and 89, so it has instructions on how to do this fix. Link to comment Share on other sites More sharing options...
WahooSteeler Posted July 12, 2020 Share Posted July 12, 2020 1 hour ago, eaglescout526 said: It's simple to do but its time consuming. If you have a general know how on splicing wires and drilling a hole through to the ECU, it can be done. Luckily I picked up a couple TSB books from 88 and 89, so it has instructions on how to do this fix. Meh, not sure if I want to deal with that, although replacing the CPS itself seems to be a bit of a pain anyway. Link to comment Share on other sites More sharing options...
WahooSteeler Posted July 15, 2020 Share Posted July 15, 2020 Parts manual showing CPS #T0739789 for '87 model years, can anyone confirm if these will work on 88-90 Renix also? Obviously a reason it is listed separately, curious why and if it's an alternative. Link to comment Share on other sites More sharing options...
eaglescout526 Posted July 15, 2020 Share Posted July 15, 2020 8 minutes ago, WahooSteeler said: Parts manual showing CPS #T0739789 for '87 model years, can anyone confirm if these will work on 88-90 Renix also? Obviously a reason it is listed separately, curious why and if it's an alternative. That should work regardless of the years but that number is a former Renault number to Chrysler number. My best guess is it started out as a 2.5L sensor and became universal for all engines and Renix systems. Link to comment Share on other sites More sharing options...
WahooSteeler Posted July 15, 2020 Share Posted July 15, 2020 1 minute ago, eaglescout526 said: That should work regardless of the years but that number is a former Renault number to Chrysler number. My best guess is it started out as a 2.5L sensor and became universal for all engines and Renix systems. So to confirm, you think it should work on Renix 4.0's from 87-90? Link to comment Share on other sites More sharing options...
eaglescout526 Posted July 15, 2020 Share Posted July 15, 2020 It should. All the sensor is looking for is the gaps in the flywheel. Link to comment Share on other sites More sharing options...
eaglescout526 Posted July 15, 2020 Share Posted July 15, 2020 Yeah catalog shows that it works for both engines and fits all Renix years. Link to comment Share on other sites More sharing options...
WahooSteeler Posted July 15, 2020 Share Posted July 15, 2020 5 minutes ago, eaglescout526 said: Yeah catalog shows that it works for both engines and fits all Renix years. Yup, just came across the Crown version on Quadratec that lists that part # for 87-90 2.5L and 4.0L. Also came across a thread from 2016 on here where Cruiser confirmed the same question. Link to comment Share on other sites More sharing options...
eaglescout526 Posted July 15, 2020 Share Posted July 15, 2020 8 minutes ago, WahooSteeler said: Yup, just came across the Crown version on Quadratec that lists that part # for 87-90 2.5L and 4.0L. Also came across a thread from 2016 on here where Cruiser confirmed the same question. Well theres 48 left of the Renault number T0739789, they run about $50, almost about the same as after market. Link to comment Share on other sites More sharing options...
WahooSteeler Posted July 15, 2020 Share Posted July 15, 2020 24 minutes ago, eaglescout526 said: Well theres 48 left of the Renault number T0739789, they run about $50, almost about the same as after market. Just ordered one as backup to the 33004761 I found and ordered. Online chat person confirmed the T# part as available, but I've had that turn out not to be true before. It was $60 plus shipping. I've learned the hard way on cheap parts, so whenever I can get OEM I'll pony up the price for that peace of mind. Link to comment Share on other sites More sharing options...
eaglescout526 Posted July 15, 2020 Share Posted July 15, 2020 5 minutes ago, WahooSteeler said: Just ordered one as backup to the 33004761 I found and ordered. Online chat person confirmed the T# part as available, but I've had that turn out not to be true before. It was $60 plus shipping. I've learned the hard way on cheap parts, so whenever I can get OEM I'll pony up the price for that peace of mind. Was it Vintage parts you spoke to? But that's not bad and will be worth it in the long run. Link to comment Share on other sites More sharing options...
WahooSteeler Posted July 15, 2020 Share Posted July 15, 2020 No on Vintage, but I had checked them on the other part #s ironically. Looks like I could save $13 through them, might cancel the other and go through Vintage. Link to comment Share on other sites More sharing options...
