robbie95 Posted April 21, 2019 Share Posted April 21, 2019 I'm assuming me switching over to full synthetic has had something to do it with it. (Made the switch about 6 months ago) But is it something I should be too concerned about? Seems to run fine just a little noisy.. Link to comment Share on other sites More sharing options...
Jeep Driver Posted April 21, 2019 Share Posted April 21, 2019 What oil are you using? what weight? What is your pressure at idle? Syn or not, has nothing to do with it. Link to comment Share on other sites More sharing options...
robbie95 Posted April 21, 2019 Author Share Posted April 21, 2019 20 minutes ago, Jeep Driver said: What oil are you using? what weight? What is your pressure at idle? Syn or not, has nothing to do with it. running mobil 10w-40 full synthetic, not sure. How would I check that? Link to comment Share on other sites More sharing options...
robbie95 Posted April 21, 2019 Author Share Posted April 21, 2019 alright, so i think its pretty high... on startup its between 50-55 psi that was after a 5 min drive to the auto store btw. Link to comment Share on other sites More sharing options...
Minuit Posted April 21, 2019 Share Posted April 21, 2019 If those numbers are accurate, those are good numbers. Link to comment Share on other sites More sharing options...
robbie95 Posted April 21, 2019 Author Share Posted April 21, 2019 6 minutes ago, Minuit said: If those numbers are accurate, those are good numbers. I just went out and bought a gauge to read it so hopefully its pretty close to accurate. Revving it up I'm seeing betweeen 65-70. I've never had problems with the trucks, just recently started hearing a ticking and its driving me nuts, its always been a little noisy but this noise is new. Link to comment Share on other sites More sharing options...
gogmorgo Posted April 21, 2019 Share Posted April 21, 2019 Switching to synthetic can sometimes loosen up old deposits and float them around, but it shouldn't cause permanent damage and I doubt it has much to do with any noises. Hydraulic lifters take up the slack in your valve lash as they wear, but eventually the lash exceeds the range they can make up, and the valvetrain starts making that clattery diesel noise. Running some Seafoam through it may help, or probably won't. If you want to deal with it, likely you're looking at changing out lifters and pushrods. Then once you're in there you may as well do a ton of other stuff, which can start to add up. Or you can just leave it and let it clatter away happily like mine does. Link to comment Share on other sites More sharing options...
robbie95 Posted April 22, 2019 Author Share Posted April 22, 2019 14 minutes ago, gogmorgo said: Switching to synthetic can sometimes loosen up old deposits and float them around, but it shouldn't cause permanent damage and I doubt it has much to do with any noises. Hydraulic lifters take up the slack in your valve lash as they wear, but eventually the lash exceeds the range they can make up, and the valvetrain starts making that clattery diesel noise. Running some Seafoam through it may help, or probably won't. If you want to deal with it, likely you're looking at changing out lifters and pushrods. Then once you're in there you may as well do a ton of other stuff, which can start to add up. Or you can just leave it and let it clatter away happily like mine does. Yeah, I plan on just letting it clatter away for now if it isn't anything major. Gonna put a new engine in it hopefully within the next couple years. Link to comment Share on other sites More sharing options...
benjy_26 Posted May 20, 2019 Share Posted May 20, 2019 My brother's '95 XJ with a 2.5 sounds like a diesel, too. He bought it that way around 4 years ago with the idea of doing a rebuild on it. Still going without any sign of dying. Those 2.5's are tough. Link to comment Share on other sites More sharing options...
gogmorgo Posted May 21, 2019 Share Posted May 21, 2019 Since I posted earlier I've changed my power steering pump, and a lot of the dieselly clatter from my 2.5 has disappeared. Worth looking(listening?) into if you've got a stethoscope, or reasonable alternative. Link to comment Share on other sites More sharing options...
