I have 4 center caps that are in pretty good shape, but dirty.  What would be the best way to clean them up without causing any damage?
I thought you already did this some time ago?
My concern with compounds is getting it into the plastics........you'll never get it out.
Someone mentioned Never Dull............this is one of the few times it might be worth using.
I did have another set. I found these at a junkyard recently.
18 hours ago, Strokermjcomanche said:
I don't see any compound anywhere...
Those look great!  Did they look similar to mine before?
  • 5 years later...
hi this is an old thread but what exact products did you guys use? i.e. what is medium compound and glass cleaner? I've got turbine caps too and want to get it right!
1 hour ago, Dan Schachner said:
Bumping because I am also curious what medium compound is.
Something like this. Doesn't need to be this exact product, but it would say medium cut on the bottle somewhere. I'd use that with a microfiber towel.
Just about any product advertised as chrome polish will work.  Then it's a matter of masking off the painted area and repainting it, if desired.  I've seen the painted area be a metallic gray color, or also black.  Then if the center sticker is missing, you could order a replacement from https://3dcarstickers.com. They might not be an exact copy, but close enough for a daily driver.
