Ok... so I was out late and was gonna leave for home when I realized my head lights weren’t working. I then proceeded to check the other lights on the truck and nothings working. The brake lights, blinkers, hazards, headlights, and interior lights are all out. I check the fuses and they all look fine. As I went to pick it up the next morning, it stalled on the freeway. Had to have it towed home, but right when I got it home it started up right away. I’m not handy with electrical and am wondering if you guys know what’s wrong.
1 hour ago, Jacoblopes said:
do you think it could be the ignition switch?
The lights should work with the ignition off -- or not working. Start as Ωhm suggested.
If it was the headlights alone, I would look at the connector that is located on the driver side header panel, below the air cleaner box.  Every XJ/MJ I have looked at had bad corrosion at this connector which is for all the lights on the front end.
But coupled with a random engine shut off, go with what Ohm and Eagle said.
the link in my signature will have the link to Cruiser's website which covers grounds and such.  eventually you should do all of his MJ tips that are applicable to your year. :L:  .
On 3/15/2019 at 3:07 PM, Ωhm said:
Ok, I did that then I took out the ignition switch, and it turns out the connectors that plug into it were melted. i just put in new connectors but all the lights still aren't working and now I'm not even getting a spark
Pull the HAZ/STOP fuse out. Determine if one terminal or the other terminal has 12vdc (testlight will also work) on it.
