NEO auto Posted March 12, 2019 Share Posted March 12, 2019 My 87 Comanche has rust by the wheel wells. It's like this on both sides. Would it be that difficult for a body shop to fix? On the other side of the bed, there is a weird dent (it's towards the back under the body line, 3rd picture) The rest of the bed is in pretty good shape (Other than a bent tailgate). Would it be worth investing in a new bed, or should I repair the one I have? I found these new bedsides online at ZM Jeeps: http://stores.zmjeeps.com/bed-side-mj-comanche/ Does anyone have experience with bed repairs? Thanks for any advice. You can see the dent towards the back (it is a long line) I found these new bedsides online at ZM Jeeps: http://stores.zmjeeps.com/bed-side-mj-comanche/ Link to comment Share on other sites More sharing options...
Dzimm Posted March 12, 2019 Share Posted March 12, 2019 Easily repairable. Those bedsides don't have the stamping for the fender flares so you'd be in a similar spot to where you are now. On my red truck I used front fenders to repair the wheel arch. They aren't a perfect match but are close enough and your flare will cover it anyway. Obviously best option is to find someone cutting up a bed. Link to comment Share on other sites More sharing options...
Pete M Posted March 12, 2019 Share Posted March 12, 2019 sadly, it's always worse on the inside. also, I've seen front fenders used as patch panels to good effect. also, rust free beds exist down south. Link to comment Share on other sites More sharing options...
WahooSteeler Posted March 12, 2019 Share Posted March 12, 2019 Best bet is to start looking for a rust free bed. The problem with a body shop doing it is behind your flares it's probably worse than you can see now, as Pete pointed out. And specifically, if the embossed ridge around the wheel opening that the flare mounting brackets attach to are rusted out, you're talking some long hours for a talented guy to cut out, replace and reform those ridges. Link to comment Share on other sites More sharing options...
Jeep Driver Posted March 12, 2019 Share Posted March 12, 2019 If you were to cut and patch panels............here's your donor. Link to comment Share on other sites More sharing options...
