DIRT_NASTYY_ Posted February 11, 2019 Share Posted February 11, 2019 I grew up driving Jeep Cherokees, and my daily all through college was a budget rock crawler XJ. Ultimately the motor died from abuse at around 200k miles a few years ago. I got a reliable daily and the goal was to rebuild that Cherokee from the ground up…. until I spotted this Comanche on Craigslist. I’ve always wanted a Comanche, and after going to look at it in person I was sold. It’s a 92 2WD long bed with the HO 4.0, and I have all the parts needed to convert it to 4WD. The game plan was to drive this truck to KOH, which gave me 4 weekends since I don't store the truck at my place. So I pulled the front axle, drivetrain, suspension, and any little piece I could use off my XJ. First job was to give the front axle some love. I purchased an Arctec truss with Currie Johnny Joints, Solid diff cover, Ten Series tube seals, ball joints, and started to replace everything. I cleaned the axle down, propped the truss into place, and followed the instructions I got with the kit. The truss needed to be clamped down onto the axle on the backside as there was some gap between the truss and axle tube. First I just tacked all touching parts to help prevent any warping. Next I welded it on opposite sides for 1” intervals, and allowed it to cool for 15mins between welding the next spot. Once all the tubes and end were done it was time for the cast. I read a lot about this, and was a little nervous as this is my first major welding project. My buddy held a torch and heat sensor and warmed it up, but the air was so cold so we couldn’t keep it above 200-250 without constant applied heat. (using MAPP gas) So while it was sitting at 250ish, my friend would concentrate on one area until it hit 325, and when he moved to the next spot I would weld behind him, and I chased him around the axle. When we finished 2 people picked it up by the knuckles, and one person wrapped it in a welding blanket, and we let it sit overnight around 12 hours. (sorry lack of photos, it all happened so fast) Next morning it all looked good to me, and seems strong! With that done and the axle assembled, it was time to start putting parts on! The rear was pretty straight forward, new leaf springs and used a Dodge Dakota brake line. One thing that surprised me was the shock, I had Fox 2.0 shocks on my Jeep (for a 4.5” lift kit) and wasn’t sure the rear shocks would fit after reading some posts. After measuring in the OEM shock mounts I have around 3.5” down and 4.5” up, and figure the leaf springs would settle with weight in the bed. I also lucked out on the leaf shackles, as the stock ones were too short. I had some aftermarket extended hangers from my old XJ and they worked out well. I’m hanging onto the stock springs for SOA down the road. Originally I was planning on using my old steering linkages as I had the solid tie rod from a Grand Cherokee, but the tie rod ends were super worn out. I ordered some new steering parts with my ball joints, but I didn’t check the steering parts when I got them and none of it fit together. I decided to pull the trigger on Ruff Stuff’s Heim steering kit. Link to steering build; https://comancheclub.com/topic/57502-ruff-stuff-34-heim-steering/ As for the front end the whole thing came off, we just unbolted it from the body and rolled it out on the stock wheels. . From my old Jeep I had those Fox shocks, 4.5” rough country coil springs, and some generic extended lower control arms. We got the axle bolted in and the coils in place. I decided to change the lower shock mount because the pin bent the mounting area pretty bad. I welded on a square plate with shock tabs, and gave it a little lean into the body. I also picked up some extended brake lines from Rough Country along with one of their HD Track Bars. I plan on doing a lot of weekend highway driving in this thing to go wheeling and camping, so I chose to get some Cooper Discovery STT Pro’s since I read they are not as loud as traditional mud terrains. I have about 350 miles on these tires now and they have been great so far. I also took a chance and mounted them on Crager V5 15x10 rims. I’ve read some people saying you can’t air down as far on 10” rims, and some people say they’ve never had a problem. I just liked the idea of a wider footprint and the look of a more filled out tire. After putting the tires on it was time for some fender trimming. The rear doesn't rub bad, but the front needed a lot cut. Here is a guide how to trim and keep your stock fender flare! https://comancheclub.com/topic/57504-relocated-front-fender-flares/ After installing everything I put around 50-75 miles on the truck to find any other issues and then I hit the road! I loaded up and drove 2 hours out to Johnson Valley for KOH. Although it was still only 2WD, I was stoked to get a lot done and put about 300 miles on the truck and see how everything was going to work. This truck cruises 65-70mph on the highway with no issues, and felt great ripping around the desert all week. I'll be doing the 4WD conversion early March and plan to document the swap as I go. Link to comment Share on other sites More sharing options...
JMO413 Posted February 11, 2019 Share Posted February 11, 2019 Very nice truck. They front axle definitely looks strong. Can't wait to see the rest. Link to comment Share on other sites More sharing options...
Darren Posted February 11, 2019 Share Posted February 11, 2019 Nicely done man. Link to comment Share on other sites More sharing options...
DIRT_NASTYY_ Posted February 20, 2019 Author Share Posted February 20, 2019 Got the motor and transmission from my old XJ separated finally. It's an AW4 with an NP242, still waiting on some other parts to get here before I can start swapping it all in. Link to comment Share on other sites More sharing options...
DIRT_NASTYY_ Posted March 11, 2019 Author Share Posted March 11, 2019 Making slow progress on this thing. Spent Saturday mocking up the new exhaust and pulling the trans, however I got sick and couldn't get much done on Sunday. Hoping by the end of this coming weekend we'll have the 4WD swap completed! If anyone is looking to do this swap, I found some great info that has been helping me out; https://www.pullapart.com/video-library/videos/how-to-pull-a-jeep-40l-automatic-transmission-jeep-cherokee-grand-cherokee-and-wrangler/ https://www.naxja.org/forum/showthread.php?t=954587 https://www.naxja.org/forum/showthread.php?t=954587 I looked at a few exhaust options, definitely wanted something tame because my ears can't handle long drives in loud cars anymore. I ended up going with a Dynomax Ultra Flo-Welded and will be welding a flex pipe into the front portion of the exhaust; https://www.amazon.com/gp/product/B00029J3CU/ref=ppx_yo_dt_b_asin_title_o06_s02?ie=UTF8&psc=1 Finished welding on all the hangers and stuff, then set it to the side and proceeded to pull the transmission. Unplugged 3 sensors, cooling lines, shifter linkage, flex plate bolts, cross-member, then mounting bolts, badda-boom badda-bing it was out within an hour! I pulled the bench seat out and started working on getting the T-Case shifter handle installed and my new Novak adapter linkage kit started, However I ran out energy and could no longer breath out of my nose, so I'll be picking it back up next weekend. Bonus doggo photo! Link to comment Share on other sites More sharing options...
DIRT_NASTYY_ Posted March 18, 2019 Author Share Posted March 18, 2019 Got the carpet all pulled out this weekend and there was more rust than I expected. Thinking the cowl is leaking because the carpet was still damp underneath after all the rain we just got. I took a power drill with a wire brush and cleaned up all the rust, luckily it was almost all surface rust. The section closest to the door however was pretty chewed up. I was able to clean it down to bare metal, and there are a couple small holes I will be patching up later. I painted it with some rust-preventative paint in the meantime, and will be driving it without carpet or anything until we come back to re-do the interior later. With the transmission out I got started installing the shift lever for the t-case and brackets for the Novak Cable Shift kit. With all the prep work done, it was time to put the donor transmission in!! Everything is bolted up, and I replaced some of the hardware with Grade 8 bolts (those star bolts on the top, the cross-member hardware, and the transmission mount bolts) I did notice the TV Cable was shorter than the original one, and I had to re-route it. I'm thinking maybe because this donor came out of a renix era Jeep it was a different length because it mounts to a different point. The speedo sensor is also too short and I need to extend the wiring. Other than that everything was completely plug and play. All that is left is get the rear drive shaft shortened and finish the exhaust. Link to comment Share on other sites More sharing options...
DIRT_NASTYY_ Posted April 15, 2019 Author Share Posted April 15, 2019 Wrapped up the last bits of the 4X4 swap, and had to do some minor maintenance. I had some Brown Dog motor mounts that had never been mounted laying around, and had a coolant leak to figure out. After some quick inspecting, I found the source of the leak; Took it out for a quick test drive and everything is running smooth and has zero leaks for now. Truck is running smoothly and I plan on driving out to Death Valley in 2 weeks. Going to try and make some rock sliders in the near future, and will start working on the interior at this point Link to comment Share on other sites More sharing options...
DIRT_NASTYY_ Posted August 5, 2020 Author Share Posted August 5, 2020 Finally got the ball rolling after some recent life distractions, but with all the free time in quarantine I was able to finally finish the interior revamp. The interior on this truck has bugged me since the day I picked it up. The carpet was wrecked, the trim was beat up, the seat was beyond worn out, none of the courtesy lights worked, the “aftermarket stereo” only played out of 1 speaker, and the overall features were as basic as they come. Took it down to pretty much bare bones and decided to start fresh. There was some rust on the passenger side floor but other than that it was a clean slate to work with. From the ground up I added sound deadening on the floor, rear cab wall, firewall, and on the roof. Then lined it with flame retardant padding under the new carpet in hopes it would help insulate the cab. I picked up an upholstery kit for the bench seat from RayBuck Auto, and while it was apart I added some burlap over the springs and added a little foam on top for some extra support. I also added in some seat heaters and ran the wiring for the switch to the door handle panel. Behind the bench seat I mounted the amp and wrapped the cab cover piece in brown canvas. On either side are 6x9 Kenwood speakers on some custom platforms I made to mount the boxes against the cab wall. Unfortunately I could not get these creases in the carpet out, tried a heat gun, then an iron, then steam. Gave up and figured it would rarely be seen. Most of everything in the dash was swapped out. I added an XJ gauge cluster, a Kenwood head unit that controls the entire Kenwood sound system, swapped the broken cigarette lighter for a dual USB charger, added a clinometer on top of the dash and wired it into the gauge lights, installed a trans temp gauge with a switch plate that swaps out the useless plastic plate next to the gauges, and made a custom switch plate for 2 rocker switches on either side of the steering wheel. I also swapped every bulb for an LED version. All the switches are pre-wired into a custom fuse / relay box under the hood, so I have room for adding accessories as the build continues. You can also see my mini center console converted into cup holders. I was able to find wagoner door panels with crank windows to swap out the old door panels and match the other wood trim features. I also added the triangle flip windows with new window seals. Here is the final before and after comparison, this truck feels completely different now and will be much more enjoyable for long drives. And here is a video showing the new courtesy light setup. LED bulbs in the B pillars, and LED strips in the foot wells and along the bottom of the doors. Link to comment Share on other sites More sharing options...
Pete M Posted August 5, 2020 Share Posted August 5, 2020 looks fantastic! did you ever find the water leak? Link to comment Share on other sites More sharing options...
DIRT_NASTYY_ Posted August 5, 2020 Author Share Posted August 5, 2020 11 minutes ago, Pete M said: looks fantastic! did you ever find the water leak? Yeah I am pretty confident it is coming from the cowl, my last XJ had the same issue. I was worried it would be the heater core but that looked fine and it never runs low on coolant. I'll be sealing it up eventually, but in the meantime I treated the floor with POR15 and it's kept in our shop in SoCal so I am not too worried about it for the time being. Link to comment Share on other sites More sharing options...
Pete M Posted August 5, 2020 Share Posted August 5, 2020 that's smart. don't forget to check the HVAC seal and windshield too. Link to comment Share on other sites More sharing options...
DIRT_NASTYY_ Posted August 5, 2020 Author Share Posted August 5, 2020 3 minutes ago, Pete M said: that's smart. don't forget to check the HVAC seal and windshield too. Didn't even think about checking the seals themselves for leaking! Thanks for the heads up Link to comment Share on other sites More sharing options...
Pete M Posted August 6, 2020 Share Posted August 6, 2020 every single gap or opening in the cab has leaked for some poor soul at some point in time. they should ALL be inspected and renewed. I once had a windshield leak in my 86 that dribbled down inside the A-pillar before trickling out at the floor. Link to comment Share on other sites More sharing options...
Rob S Posted August 9, 2020 Share Posted August 9, 2020 Truck is looking great. I like that lift/tire combo. Link to comment Share on other sites More sharing options...
Swampy Posted August 16, 2020 Share Posted August 16, 2020 Wow that is a clean interior. I am speechless Link to comment Share on other sites More sharing options...
