1986 Comanche No Start Condition
20 minutes ago, jdog said:
A picture would help clear up the confusion,  I'm thinking it's the idle solinoid that is unplugged
IMG_0585.jpg.cae6a7bc48e15dc6265eb17fbee73eb9.jpgIMG_0586.jpg.faa422053774fb79140a77b8d5b8ead8.jpgIMG_0589.jpg.42c7db8c3afd4e2590f46cb3fa6a2768.jpgIMG_0588.jpg.574495d21e93127cd10c57572714825e.jpgIMG_0587.jpg.bcfb5de531b3a1d047166c35cea69e6b.jpgj.jpg.b2b85d8a5a2c6c15ea578a606d7fcd97.jpg
See these photos.  I believe it is in fact the TPS not plugged in.  In the first picture it is the sensor resting against the throttle that isn't plugged in. Photo of Jeep because we need to get it on the road.
  • 1 month later...
All,
Thanks for your help on the previous issue.  I ended up taking it to the shop and it was a wiring issue with the MAP sensor.  Truck has been running great until this morning....it was running fine then died.  It will crank over but won't hit a lick.  Any suggestions?  I'm at work now and didn't have time to trouble shoot the basics.
  • 3 weeks later...
On 8/20/2021 at 3:26 PM, jdog said:
Can't tell you to just replace with out testing it first
Hey thanks for helping out before..it ended up being wiring to the MAP sensor.  I am having a different problem now.  The Jeep was running fine and all the sudden died while driving down the road.  Will turn over but not getting any fuel out of the tank.  I had just replaced the fuel pump but maybe its went bad already.  Thanks for any insight.
