Instrument lights and gauges stopped working
I drove to a store tonight and everything was working just fine: cluster lights and all gauges.
I got back in to the truck to head home and I noticed the most of the dash lights were out.  One or two on the right side were lit up - speedo and oil pressure - all the others were out.  I could also see that none of the gauges were working: temp was pegged to the right, the other three (gas, oil, alt) were pegged to the left.  Both the green turn/flasher lights were on. I could see the tach moving, but it didn't look like it was reading correctly (it was dark and I was driving).
I could see in my mirror that my tail lights were on and the turn signals worked.
When I put on my turn signal, the tach needle bounced in sync with the turn signal.
Also, I think my high beams were on.  A few people flashed me as I drove home.
All this just occurred tonight.  I have not had any electrical issue previously.  I have not played with or modified any electrical part on the truck in months. The parts I did work on were in the engine bay and had nothing to do with the lights or dash.
When I got home, I flipped the high beam switch and it looked light the HB were on.  I had not turned them on when I first drove it.
And the last piece of info:  when I turned off the lights, all the gauges appeared to work correctly.
WTF?!?!?
15 minutes ago, DirtyComanche said:
That's smelling a lot like a bad ground.
That could be, although, I did do Cruiser's dash ground upgrade.
I have an older light switch I will throw in to it.  ( I kept the previous light switch from a prior "parts cannon" repair.  Changing the switch did not fix the original issue, so I kept the old one.)
Found the problem.
and the winner is....Ohm!  The C203 connector came loose.
I pushed it in tighter and all the gauges and lights work as AMC/Jeep intended.
Thanks for your help, always appreciated.
