mrmel2you Posted August 8, 2018 Posted August 8, 2018 I have a '90 MJ, 127k miles showing, head was rebuilt 2 years ago (4k miles on it) fuel injector and fuel regulator were replaced at the same time. 2wd, swb, 2.5, 4 speed, 4:10 rear, '96 XJ buckets and tilt wheel, custom homemade center console, Leer topper included. This MJ is complete and running (my daily driver), fuel sending unit is new, not rebuilt or swapped out. Front rotors/calipers/brake pads/wheel bearings have been replaced, new full exhaust from manifold to tailpipe. Engine does not smoke, no leaks and no rattles.I am offering this MJ in trade for a decent MJ driver's side door (color unimportant, but prefer blue) and a decent 4.0 engine. I say "decent engine" because I have one already that knocks and smokes---do not need another one. Feel free to call me (Papa Mel) for more info @ (785) 969-8013, please send text before calling, my phone is set to block "unknown" numbers.
a bum with money Posted August 8, 2018 Posted August 8, 2018 15 minutes ago, mrmel2you said: is the console stock or what did you get it out of?
Wounded_Fighter Posted August 8, 2018 Posted August 8, 2018 2 hours ago, Pete M said: you need a price listed. 4 hours ago, mrmel2you said: I am offering this MJ in trade for a decent MJ driver's side door (color unimportant, but prefer blue) and a decent 4.0 engine. dunno if it counts but he kinda dose? lol
MeanLemons Posted August 8, 2018 Posted August 8, 2018 4 hours ago, a bum with money said: is the console stock or what did you get it out of? He said custom console
mrmel2you Posted August 8, 2018 Author Posted August 8, 2018 Maybe I should have posted this in the "WANTED" section? (Pete, if this post is not allowed here, can you move it there for me?) I made the center console, has two cup holders that will hold 2-32oz. cups. The cubby can hold up to 24 cans of your favorite beverage and still have some room left over. Was built from 1/2" plywood and 3/8" MDF board, sprayed with bedliner inside and out and finished off with 3 coats of satin clear poly' (wanted it to last until I got the new built).
Pete M Posted August 8, 2018 Posted August 8, 2018 um, I don't understand. why couldn't you sell the truck and then go buy what you need?
a bum with money Posted August 9, 2018 Posted August 9, 2018 4 hours ago, mrmel2you said: Maybe I should have posted this in the "WANTED" section? (Pete, if this post is not allowed here, can you move it there for me?) I made the center console, has two cup holders that will hold 2-32oz. cups. The cubby can hold up to 24 cans of your favorite beverage and still have some room left over. Was built from 1/2" plywood and 3/8" MDF board, sprayed with bedliner inside and out and finished off with 3 coats of satin clear poly' (wanted it to last until I got the new built). I like the height of the armrest and the cup location. Looks good.
mrmel2you Posted August 9, 2018 Author Posted August 9, 2018 Thank you. Took a bit of planning, but liked the way it turned out. Was in the middle of making a new one, then I bought the other MJ. New console was going to run from the back wall of the cab all the way under the dash. Heater vents were going to be relocated to the sides, 4 port USB hub, 2-12v power outlets and phone/tablet mount was to be put into it. Here's a pic when it was almost finished, still had to mount the cup holders in it.
mrmel2you Posted August 9, 2018 Author Posted August 9, 2018 I left the top 4 screws showing for easier removal of the top cover, in case I wanted to add switches/USB ports/power outlets later on.
Archived
