yellaheep Posted July 20, 2018 Posted July 20, 2018 Pair of MJ tail lights. Good usable condition with cracks as shown. Left cracked into the back up lens, right cracked above the back up lens. Mounting tabs and holes are as they should be. $80 shipped. SOLD PENDING FUNDS MJ emergency brake assembly. Ratchet and action all work as it should, good solid function. $50 shipped. SOLD PENDING FUNDS MJ spare tire mount/cable winch. $45 shipped SOLD PENDING FUNDS
TheDude Posted July 21, 2018 Posted July 21, 2018 Those lights are damn tempting..Sent from my iPhone using Tapatalk
Strokermjcomanche Posted July 21, 2018 Posted July 21, 2018 I'll take the winch when I see you next week . Thanks
a bum with money Posted July 21, 2018 Posted July 21, 2018 yella, I will take the e/brake assy. Bryce
yellaheep Posted July 23, 2018 Author Posted July 23, 2018 Bryce, PM sent. I found another e-brake assembly with cable, again, perfect operation. $80 shipped. And another spare tire mount/cable winch assembly in excellent condition. $45 shipped (no photo, but very similar in condition to the other)
TheDude Posted July 23, 2018 Posted July 23, 2018 If the tire winch will fit a long bed I'm interested. Sent from my iPhone using Tapatalk
yellaheep Posted July 24, 2018 Author Posted July 24, 2018 Re: tire winch assembly - For the life of me, I can't recall if there's any difference in the part itself for long or short bed. I'm leaning toward them being the same, just difference in the way they mount under the truck. If anyone knows, post up. I'll have to look closer at the two I have and see if there's any difference between them, right now, I have to say they're exactly the same.
MJsNotDead Posted July 24, 2018 Posted July 24, 2018 On the tire winch assembly.. mine ('88 Long Bed) bolts to the frame. Bolt pattern there looks identical to mine. Not sure what the extra black flat sheet (taco'd shape bolted to the tire winch) metal is? Have better pics of it? Have the winch bar for it? These are good prices with shipping.
Strokermjcomanche Posted July 24, 2018 Posted July 24, 2018 3 hours ago, yellaheep said: Re: tire winch assembly - For the life of me, I can't recall if there's any difference in the part itself for long or short bed. I'm leaning toward them being the same, just difference in the way they mount under the truck. If anyone knows, post up. I'll have to look closer at the two I have and see if there's any difference between them, right now, I have to say they're exactly the same. They are the same , except on the long bed the black bracket doesn't get used and the crank tube is longer on the LWB models vs the SWB model .
yellaheep Posted July 24, 2018 Author Posted July 24, 2018 Well there you have it. I do have ONE crank/jack handle.
yellaheep Posted July 25, 2018 Author Posted July 25, 2018 55W KC lights. I have a switch/wiring kit to go with it. $45 shipped. Maroon and black interior pieces - what you see is what I have. PM or Text and we'll figure it out. ALL BLACK ITEMS - SPF WITH A BACK UP. 2 pairs of Late model Agate manual window front door panels - for MJ late model door conversion w/o power windows. I have a box to ship one pair of these in, would have to find another if someone wants the other set shipped. $55/pair shipped. MJ center console insert with e-brake delete filler. $30 shipped. SPF '88 Fuel pump/sending unit assembly. $55 shipped SPF '85 2.8 V6 (?) Pick up / sending unit assembly. $25 shipped Short bed e-brake cable assembly for D35. $55 shipped Nice untorn/undamaged shifter boot. $10 if sent with another item, $15 shipped. SPF A/C delete pulley and bracket for H.O. era engines $25 shipped Sun visor clip assemblies, gray and maroon. $10 each if sent with other item, $15 ea. shipped. Black mini console. In good condition, has 2 screw holes from CB mike clip, and one broken mounting tab. $45 shipped SPF
yellaheep Posted July 26, 2018 Author Posted July 26, 2018 Ok, quite literally the moment after posting the black interior parts, a local guy claimed them. Should that fall through, Stroker is next in line. Saveeveryjeep: Console panel and '88 fuel pump assy are yours. SPF. Carolinajeepman: Shifter boot is yours. SPF.
Archived
