The86manche Posted April 10, 2022 Share Posted April 10, 2022 3 hours ago, Pete M said: they say they are working on HO units. Well that is good news! But until then it will still sadly be a struggle for some Link to comment Share on other sites More sharing options...
Monte721 Posted April 11, 2022 Share Posted April 11, 2022 Wow thanks for sharing! looks like around $100 shipped so not too bad. http://www.mtscompany.com/sendingunits.htm Link to comment Share on other sites More sharing options...
Big_Mark Posted April 11, 2022 Share Posted April 11, 2022 I'm using the MTS pump and replacement sending unit. The only issue I had was how the pump is held onto the sending unit assembly. I was able to overcome the issue with 2 hose clamps Other thank that is was bolt in as is and works great! If I don't use the hose clamps the pump falls off/pushes itself off the output hose (fuel to engine). With the clamps all is good. I think the stock assembly has some kind of metal loop/keeper assembly that hold the top of the pump in place, sadly the MTS one doesn't have that part. Link to comment Share on other sites More sharing options...
Monte721 Posted April 13, 2022 Share Posted April 13, 2022 Thanks, will keep that in mind. But after closer look, I may have a Cherokee sending unit that I pulled out of it, it has the straight fuel line inputs on the outside and looks to be shaped a little differently. I'm wondering if the entire tank and unit was replaced at somepoint. Are there any indicators on the outside of the tank if its for a comanche or cherokee so I know which sending unit to replace with? Link to comment Share on other sites More sharing options...
DirtyComanche Posted April 13, 2022 Share Posted April 13, 2022 11 minutes ago, Monte721 said: Thanks, will keep that in mind. But after closer look, I may have a Cherokee sending unit that I pulled out of it, it has the straight fuel line inputs on the outside and looks to be shaped a little differently. I'm wondering if the entire tank and unit was replaced at somepoint. Are there any indicators on the outside of the tank if its for a comanche or cherokee so I know which sending unit to replace with? The Cherokee one is quite different because it goes into the top of the tank on them. Likewise the Cherokee tank is a totally different shape (it goes behind the rear axle). A Cherokee sender does not fit in a Comanche tank without some significant surgery, and a Cherokee tank doesn't fit where the Comanche tank is. Sooooo, I'd say it probably isn't. Link to comment Share on other sites More sharing options...
The86manche Posted April 13, 2022 Share Posted April 13, 2022 11 hours ago, DirtyComanche said: The Cherokee one is quite different because it goes into the top of the tank on them. Likewise the Cherokee tank is a totally different shape (it goes behind the rear axle). A Cherokee sender does not fit in a Comanche tank without some significant surgery, and a Cherokee tank doesn't fit where the Comanche tank is. Sooooo, I'd say it probably isn't. Maybe later cherokees had top mounted fuel pumps but the ones up until 96 were similar as they mounted more to the side of the tank. You're right about the tank itself though but there's quite a few people who have put cherokee senders into mj tanks. The biggest problem most seem to discover is the xj sender is shorter and won't sit to the bottom of the tank qnd other times it's just the orientation of the metal lines for the sender need tweaking. So there is a possibility that there could be a cherokee sender in there. Link to comment Share on other sites More sharing options...
Monte721 Posted April 13, 2022 Share Posted April 13, 2022 OK, its certainly side mounted towards the top. Theres no indication of any major modifications to the tank. If it was an xj tank and I got a replacement mj sending unit thats supposed to be in there, that would not work? From reading other posts and because It looks like a slightly different shape, it sounds like it could be modified but instead of getting to that, I'm wondering if theres any exterior indicators of what the tank is, I can't seem to find any. Link to comment Share on other sites More sharing options...
Big_Mark Posted April 14, 2022 Share Posted April 14, 2022 Here's some pics of my gas tank with the new pump sending unit assembly installed in the Jeep (well mostly, there was some in and out and adjusting of the tank straps and is why the E brake bracket is hanging) Here's the new tank on the bench before it went in Here's the original tank without the pump sending unit assembly Hopefully these pics help you identify your tank. this is the 18 Gal tank Link to comment Share on other sites More sharing options...
Monte721 Posted April 14, 2022 Share Posted April 14, 2022 5 hours ago, Big_Mark said: Here's some pics of my gas tank with the new pump sending unit assembly installed in the Jeep (well mostly, there was some in and out and adjusting of the tank straps and is why the E brake bracket is hanging) Here's the new tank on the bench before it went in Here's the original tank without the pump sending unit assembly Hopefully these pics help you identify your tank. this is the 18 Gal tank Thanks! At first I thought it looks like the same tank, but I'm pretty sure mines not 18 gallons (Its possible the float arm was short and there was always more fuel in there than I thought). The MTS agent thought mine is a smaller aftermarket tank one with a XJ sending unit. I hate to ask a favor but do you have rough outer dimensions of your 18 gallon? My tank is 30"x17" at the squared lip x roughly 12" tall with the FSU hole pretty much in the middle (aftermarket xj and mj tanks look offcentered) Link to comment Share on other sites More sharing options...
DirtyComanche Posted April 15, 2022 Share Posted April 15, 2022 On 4/13/2022 at 6:53 AM, The86manche said: Maybe later cherokees had top mounted fuel pumps but the ones up until 96 were similar as they mounted more to the side of the tank. You're right about the tank itself though but there's quite a few people who have put cherokee senders into mj tanks. The biggest problem most seem to discover is the xj sender is shorter and won't sit to the bottom of the tank qnd other times it's just the orientation of the metal lines for the sender need tweaking. So there is a possibility that there could be a cherokee sender in there. You got me there, I was thinking about newer ones for some reason. Probably because I've been trying to rid my life of steel gas tanks. Link to comment Share on other sites More sharing options...
Big_Mark Posted April 18, 2022 Share Posted April 18, 2022 This is that tank I bought from Oreilly's Measurements from the description: Length (in): 29-3/4 Inch Height (in): 13-5/8 Inch Width (in): 17-1/4 Inch Capacity (Gal): 18 Gallon I'll go measure the old tank if you still need other dimensions, this seemed like the most efficient way to get you the info you requested. Link to comment Share on other sites More sharing options...
Monte721 Posted April 18, 2022 Share Posted April 18, 2022 Thanks for that, I believe thats close enough to mine that its probably the same and roughly the same capacity. I'm thinking what happened was a previous owner stuck an xj sending unit in it so the gage is a little off and shows empty with several gallons left in the tank if that makes sense. I ended up ordering both sending units and will try the mj one out first and if it doesnt work will stick the xj one back in it and call it good. Thanks for all the responses. Link to comment Share on other sites More sharing options...
