Grommet on the floor
Anybody know where I can find another grommet for the floor on the back? (There’s wiring going into there from the fuel pump harness. Not sure what those would be for.
And if the knockout hole next to it would also be the same size and I can use the same grommet on that hole?
I'm trying to wire in a new circuit in that hole.
When I did my 97+ swap I ran into the same problem you are having, I was unable to find a grommet that size.
I ended up taking it out, cutting open the grommet to fit the wires I needed, then using Black RTV to seal the grommet back up, then reinstalled.  Basically permanently attaching the grommet to the new wires just like the old ones.
Same thing I did
