Pete M Posted April 24, 2018 Posted April 24, 2018 of course it does. still might look pretty sweet as wall decoration.
Minuit Posted April 24, 2018 Posted April 24, 2018 The seller should have moved the cluster out of that shadow so that it doesn't look like it has a HUGE crack in it.
Pete M Posted April 24, 2018 Posted April 24, 2018 wait, why does the NOS cluster have 0.3 miles on it? seems more likely it was removed early on in favor of the better cluster. a minor technicality, I know, but still.
Big Dan Posted April 25, 2018 Posted April 25, 2018 Is the electric strip (can't think of the real name for it) on the back compatible with non idiot light clusters?
HOrnbrod Posted April 27, 2018 Author Posted April 27, 2018 On 4/24/2018 at 11:22 PM, Big Dan said: Is the electric strip (can't think of the real name for it) on the back compatible with non idiot light clusters? CONDUCTOR, Printed Circuit. And no, it's completely different from the non-idiot light clusters.
dustytony Posted August 17, 2018 Posted August 17, 2018 How can you tell the difference between an idiot light cluster and a non? Is it just the panel on the left?
Pete M Posted August 17, 2018 Posted August 17, 2018 1 hour ago, dustytony said: How can you tell the difference between an idiot light cluster and a non? Is it just the panel on the left? the gauge clusters have, well, gauges. you will see the needles.
MeanLemons Posted August 17, 2018 Posted August 17, 2018 On 4/25/2018 at 12:22 AM, Big Dan said: Is the electric strip (can't think of the real name for it) on the back compatible with non idiot light clusters? https://www.cherokeeforum.com/f30/retrofitting-idiot-light-housing-241858/
dustytony Posted September 10, 2018 Posted September 10, 2018 On 8/17/2018 at 12:19 PM, Pete M said: the gauge clusters have, well, gauges. you will see the needles. Gotcha, just wasn't familiar with that terminology applied to these gauges. thanks man!
