Warren99 Posted March 9, 2018 Posted March 9, 2018 I'm looking for a 3-4 inch lift kit for my 89. I want to fit 32's under it, and also don't want to spend anything over 2,000. Any suggested brands that I should look at? Thanks
fiatslug87 Posted March 9, 2018 Posted March 9, 2018 3 hours ago, Incommando said: Zone Is anyone running the Zone J29 kit? Any reviews? Pictures?
Smokeyyank Posted March 9, 2018 Posted March 9, 2018 I only know so much from the XJ, but I'd suggest OME, Zone, IRO are good for starters. 2k should be more than enough to get a solid lift.
Warren99 Posted March 12, 2018 Author Posted March 12, 2018 Most brands don't have any for an MJ, so what do you do? Like, if you got a 4.5 inch lift in the front(from an XJ kit), then what size lift goes in the back? All I know is that XJ and MJ lifts are similar, but different.
Smokeyyank Posted March 12, 2018 Posted March 12, 2018 The front is easy and as you said is the same as the XJ. From what I've gathered for the rear you option is either going SOA or needing to get new leaf packs. I know on a XJ you can make bastard packs, don't think the same is true for the MJ. When I get a round to lifting mine I'll go SOA for rear possibly add in leaf sliders if they would work. Should net about 4.5" with the 8.25. I know Hell creek makes leafs but they are $$$. Rustys also has MJ 4" leafs, but I'm not a fan of Rustys stuff.
tacticleturtle Posted March 13, 2018 Posted March 13, 2018 Spring over in the rear and IRO front long arm. Buy front springs after to see how .ucb lift you get in the rear. That's my plan for mine. I have all of IRO's stuff on my XJ and love the flex. Customer service is top notch also. They get all my business. Oh and when my xj flexes people's jaw hit the ground
