hoenestly Posted March 4, 2018 Share Posted March 4, 2018 I did my first tune up on the mj since i bought it a few days ago, it ran like $#!& and barely wanted to stay running without me giving it some throttle. I followed cruisers first tips and cleaned connections etc. I was diving into why is runs so rough and something tells me it is the air to the engine. So when i got the jeep it had a specter cold air intake, it was covered in oil and very nasty. I got stock airbox from the junkyard and a filter and hooked it up and now it will not start, the jeep started with the other intake full of oil but the stock air box it will not. It cranks but will not start. Oh and just now I looked and the second fuel injector seems to be leaking gas, as of now and this wasn't happening before. So why would it not crank with a stock airbox but it will ( very rough) with a cold air intake. Oh and i tested it without anything on the throttle body and it also doesn't crank either. Link to comment Share on other sites More sharing options...
yxmj Posted March 4, 2018 Share Posted March 4, 2018 Does not crank? Do you mean the starter is turning the engine but it will not fire up? The air intake or air box would have nothing to do with that. Is it possible you knocked loose a connection of a sensor when you were working around the TB? Link to comment Share on other sites More sharing options...
hoenestly Posted March 4, 2018 Author Share Posted March 4, 2018 So update....Cylinder 2 fuel injector is dripping petrol ANNNNNNd after putting everything back to the original setup for when I got it with the cold air intake covered in oil....IT started up and ran, but didn't run with the stock air box. Anyway, what a good online spot to buy new 4 hole fuel injectors for mj? Link to comment Share on other sites More sharing options...
DirtyComanche Posted March 4, 2018 Share Posted March 4, 2018 eBay for the injectors, get used cleaned/flowchecked ones. New injectors are either a ton of money or garbage. What year is it? I think you probably have more issues. Link to comment Share on other sites More sharing options...
hoenestly Posted March 7, 2018 Author Share Posted March 7, 2018 I ordered some injectors and it's an 88. The idle is getting more stable as it won't cut off anymore like it used to, still runs like garbage, but I'm just counting what good i can at this point Link to comment Share on other sites More sharing options...
Skorpyo Posted March 7, 2018 Share Posted March 7, 2018 Random question, but when you re-installed the airbox did you by chance bump the connectors on the ballast resistor? If that doesn't get a good connection it'll exhibit symptoms like cranking but not firing... Just a thought. Link to comment Share on other sites More sharing options...
cruiser54 Posted March 7, 2018 Share Posted March 7, 2018 19 minutes ago, Skorpyo said: Random question, but when you re-installed the airbox did you by chance bump the connectors on the ballast resistor? If that doesn't get a good connection it'll exhibit symptoms like cranking but not firing... Just a thought. You beat me to it............. Link to comment Share on other sites More sharing options...
Skorpyo Posted March 7, 2018 Share Posted March 7, 2018 37 minutes ago, cruiser54 said: You beat me to it............. Always on my shortlist of things to check along with the vacuum lines to the map.... :-) Link to comment Share on other sites More sharing options...
