Hi all back againĀ šŸ˜ŽšŸ˜Ž well when it rains it pours so yesterday driving home from work and went to grab 3 gear and nothing felt like it was in neutral got to a red light and couldn't get it into any gear makes a weird grinding noise somehow got it into 4 th and babied it to gas station even with it idling makes grinding noise even made the noise while being towed behind the truck not sure what it is I replaced the clutch probably year and a half ago I get the feeling that maybe the syncros are bad hope notĀ so any ideas or tips will help a lot...., not really looking forward to pulling the tranny again but it is just nuts and bolts šŸ‘šŸ‘ thx allĀ
only 4 gear works? the countershaft is gone...
Ā
replace that transmission, it`s easier than rebuilding it, chevy trannies are cheap and abundant in junkyards...
The AX4 or AX5 only came behind the Wrangler, XJ or MJ, with the 2.5, no other vehicles, IOWs you won't' find them in a Chevy.
Ā
Ā
I agree though, same happened to mine..........counter shaft is toast.Ā
Ā
Ā
Ā
Find a good used one, or go to Ebay and get one for $700 that is rebuilt. With core/shipping the final cost may be about $900.Ā
Ā
Local rebuild will run you about $1200..........they will get you on parts costs.Ā
Something along the lines of this-
Ā
https://www.ebay.com/itm/Jeep-Wrangler-87-02-YJ-TJ-2-5L-4CYL-AX5-5-Speed-Remanufactured-Transmission/272814701361?hash=item3f8505fb31:g:zhkAAOSw1g9ZmwsM&vxp=mtr
Ā
Ā
They will demand core up front, you pay return shipping, core is refunded........if your shipping is $100..........your total cost is $800.
Ā
Ā
Ā
You didn't say if it was 2W or 4W...........
Ā
I've replaced my 4 times, each with a used, average used cost is about $300, you'll need to look around.Ā
30 minutes ago, Comanche kid520 said:
Ok so my tranny is shot it is a 2wd sorry bout that question will a ax 5 from a 90 fit for my 88 2.5 ???
Any 2W AX5 from any year will fit. They are all the same.Ā
50 minutes ago, Comanche kid520 said:
Even though my tranny is only a 4 speed the 5 speed will fitĀ
Yes. They are the same transmission, the AX-4 just doesn't have 5th gear.
