Pete M Posted October 9, 2025 Author Posted October 9, 2025 also I tracked down my amp issue to corrosion at the battery terminal. turns out amps don't like getting fed 8.5v.
Pete M Posted October 17, 2025 Author Posted October 17, 2025 rear pass window failed and rolled itself down. tomorrow I'll tear into it and see if it's one I've repaired already. also my tire is contacting my windshield washer pump during turns, causing a leak and draining out all the fluid. I may have to address that. big tires for life on the plus side, I made 4 runs into town to pick up 2 loads of wood and 2 1000# trips of gravel and she mostly behaved herself
neohic Posted October 17, 2025 Posted October 17, 2025 1 minute ago, fiatslug87 said: I think your MJ is feeling neglected.
Pete M Posted October 17, 2025 Author Posted October 17, 2025 yeah, well the daily has to take precedence over the truck I can't afford to drive even if it wasn't broken.
Pete M Posted November 2, 2025 Author Posted November 2, 2025 still freaks me out a bit that I can now accelerate like a normal car. well, a "normal car" if that normal car had a mufflerless diesel.
Pete M Posted December 25, 2025 Author Posted December 25, 2025 the other day I noticed that I'm already splitting open the rear aftermarket foam bumpstops so I ordered and now have installed some poly ones. haven't gone for a ride yet to see how it feels but my Jeep just barely kisses the bumpstop at rest so this might be interesting. (partly due to weight and spring sag, partly due to the aftermarket stops being way taller than the factory ones) whatever happens, I'm certain it's better than the original springs/bumpstops since they were so bad I was sitting steel-on-steel at rest. lol
Pete M Posted June 29 Author Posted June 29 so the junkyard sun visor (forgot what it came from) does a great job of blocking the sun (it's just a bit longer than factory), but because the mount isn't factory it annoyingly wobbles a bit. so I grabbed a spare visor clip (every Libby owner should have a few extra for when they inevitably break) and screwed it to the ceiling
mjeff87 Posted July 15 Posted July 15 Hey Pete, have you done LBJ's on your KJ before? I just ordered a set of them and am going to attempt to swap mine out this weekend (they appear to be originals, so getting them out is probably going to be tons of fun...). Any tips/tricks to them? I do have a decent BJ press tool, but it only has a couple collars and whatnot. I'll probably rent out the full kit from Advance or O'rileys just to have on hand if I need other pieces/parts.
Pete M Posted July 15 Author Posted July 15 unfortunately I don't have any direct experience with those. I bought rust free knuckles from the junkyard that had like-new joints installed. but my experience with the rear boomerang joint says you will definitely want the full kit. the usual tips apply: -heat -heat -heat -youtube vids
mjeff87 Posted July 15 Posted July 15 Yeah...that rear tri-ball (or whatever you want to call it) on mine probably needs replacing. I half-heartedly attempted it once and decided it was not the day to try that repair. LOL. I'll give the balljoints a shot on Saturday. Thanks
Pete M Posted yesterday at 08:55 PM Author Posted yesterday at 08:55 PM hopefully this junkyard oil cooler will help keep the high transmission temps at bay. the factory unit is integrated into the lower couple inches of the AC condenser and is buried down behind my bumper. less than ideal. the new cooler isn't actually in the fan's airflow, but space is at a premium and it's right there in front. I have a better plan, but it'll have to wait because it's way more involved. this was quick and dirty.
Pete M Posted yesterday at 09:26 PM Author Posted yesterday at 09:26 PM oh, and I spotted a fresh 05 CRD the other day and grabbed a few spare parts from it. the front shafts are unique to CRDs and now I have a spare set. (plus brakes, spindles, e-fan, hoses and some other stuff). I may go back in a couple weeks after I give other owners a chance at the engine/computer bits. I have enough of those.
neohic Posted 20 hours ago Posted 20 hours ago 4 hours ago, Pete M said: … this was quick and dirty. Don’t think of it as “quick and dirty” but more like having adjustable mounting solutions.
Pete M Posted 5 hours ago Author Posted 5 hours ago 2 hour test drive on today's junkyard run and all is well. it wasn't hot enough outside to trigger the codes, but it means I didn't screw anything up.
