Battery Hold-Down Bracket
57 minutes ago, fiatslug87 said:
The stock set up was a nut with integral washer.
Thanks, fiatslug87.
I found two of those in the pile but
like the old top bracket, they are in pretty
bad shape. :confused:
I going to try to see if they clean up.
youngfred
Pick up stainless steel nuts and washers.  The chain home stores (Lowes, Home Depot, Ace, etc.) may have stainless fender washers that will give more washer diameter to better match the size of the bracket eye.
I’d like to find a bracket in good condition like the one in your photo.
I have that as one of my choices, thanks.
Here you go:
https://www.ebay.com/itm/OEM-55010722-Battery-Hold-Down-Bracket-Direct-Fit-for-Jeep-Cherokee-Comanche-New/371401108650?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
youngfred
5 hours ago, HOrnbrod said:
Yep.
I'm gonna try to salvage my old rusted ones.
Ou-Ou Wee. :peep:
That Hood-Prop Rod(ground), seems mighty close-there, Mr. H.
Sure 'peers that way, from this angle ???
Yep or Nope ???
Quote
youngfred
10 hours ago, HOrnbrod said:
Nope. That's an old pic, the prop rod is gone now - using hood struts.
Nice battery set up.  :thumbsup:   I'm surprised to see that your hood prop rod plastic clip is in good shape.   The ones on my '88 MJ & '89 XJ were both broken so I replaced them with metal ones from newer XJ's.   Hood struts would of course solve that problem.
58 minutes ago, Keyav8r said:
Don doesn’t allow anything on his MJ to be broken, in poor shape, or even out of place.  And, of course, CHROME IS KING!
That's a good idea.   I'm going to chrome my clip!   :laugh:
