That was a prototype, I think they modified it a little.
Makes sense. Simple design. I like it. Hope it's not expensive. Could he made at home if someone was that set on it. Looks very well thought out
Sent from my SM-G892A using Tapatalk
Very similar to mine, it works good but you have to be careful since you can't see how the cable is winding on the drum very well.
I took one wrap of cable off the drum to help keep it from jamming up, that seems to have helped a lot, i recently bought synthetic rope to swap out the cable, I'm hoping it winds up a little smaller which should help too.
Will do
jeepology over on Cherokeeforum was the next who installed with the new finished touches
he says it fits perfect
https://www.cherokeeforum.com/f46/project-mercenary-224888/index59/
I guess I've seen this a long time ago. I've been following it on his Instagram but didn't notice til juat now. I thought it was a homemade set up. Looks good
I was thinking the same...
i am waiting until after Christmas to pick up a synthetic winch line because the winch cable off my warn winch has been fraying a bit
where did you mount your solenoid box?
I was trying to figure out where I can I put it so I can access it easier
1 hour ago, mnkyboy said:
My solenoid box is mounted to the winch facing the crank pulley, perk of having a 4banger.
Good to hear...
going to experiment a bit...
i have a late model 2.5 radiator fan shroud with the built in electric fan that allows you to use the 4.0 radiator
1 hour ago, fiatslug87 said:
Are you guys using the Warn M8000 or the Smittybilt 9000 winches? I'm curious which other ones will fit.
Actually I have both but I’m going to use the m8000 on this run...
