Trailhawkmj Posted February 7, 2018 Share Posted February 7, 2018 That looks awesome. I kinda regret not going with that one now. Link to comment Share on other sites More sharing options...
jbain Posted February 10, 2018 Author Share Posted February 10, 2018 Haven't been looking forward to building a rear panel for the truck. But it wasn't too bad. Time for fabric. Link to comment Share on other sites More sharing options...
jbain Posted February 10, 2018 Author Share Posted February 10, 2018 Turned out pretty good. Time to move on to something else. Link to comment Share on other sites More sharing options...
SatiricalHen Posted February 11, 2018 Share Posted February 11, 2018 On 2/10/2018 at 6:53 PM, jbain said: Haven't been looking forward to building a rear panel for the truck. But it wasn't too bad. Time for fabric. You wouldn’t happen to have any measurements or anything? I need to make one, but I wasn’t sure what to use for the board. Any tips or tricks for making one would be much appreciated! Also, do you remember how much resin you used on your headliner? I just got one and it needs some help. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
jbain Posted February 12, 2018 Author Share Posted February 12, 2018 On 2/11/2018 at 8:34 PM, SatiricalHen said: You wouldn’t happen to have any measurements or anything? I need to make one, but I wasn’t sure what to use for the board. Any tips or tricks for making one would be much appreciated! Also, do you remember how much resin you used on your headliner? I just got one and it needs some help. Sent from my iPhone using Tapatalk Expand As for the Resin I bought a gallon and probably used about half that. For the backboard I used a piece of Luan from Lowe's. If I remember right it was 46 wide 18 1/2 on the edges tapering to 16 1/4 in the center. I actually left it 48 inches wide and cut out two 1 inch Notches to slide behind the B-Pillar plastic. Link to comment Share on other sites More sharing options...
jbain Posted February 12, 2018 Author Share Posted February 12, 2018 Another long day in the garage but the HP 44 is ready to go under the Comanche. Link to comment Share on other sites More sharing options...
SatiricalHen Posted February 12, 2018 Share Posted February 12, 2018 On 2/12/2018 at 12:35 AM, jbain said: As for the Resin I bought a gallon and probably used about half that. For the backboard I used a piece of Luan from Lowe's. If I remember right it was 46 wide 18 1/2 on the edges tapering to 16 1/4 in the center. I actually left it 48 inches wide and cut out two 1 inch Notches to slide behind the B-Pillar plastic. Did you just cut the shape and then cover it and it just slides back there behind the b pillar plastic? Mine never had one and I’ve never seen one in person so I’m not 100% sure how they mount. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
natander2ksometime Posted February 12, 2018 Share Posted February 12, 2018 On 2/2/2018 at 12:36 AM, jbain said: The new bumper for the MJ showed up this evening. Seems legit. Expand Love the white MJ! This is going to be super nice! I have a kinda strange and specific question about the rear bumper. How much material (front to back) is there in the section directly underneath the taillight? I'm wanting to put a tire carrier on something in the future and need to fit a 1.5" shaft directly under the tail light, with a bit of wiggle room front to back. I'd appreciate any info you could get me! Link to comment Share on other sites More sharing options...
jbain Posted February 13, 2018 Author Share Posted February 13, 2018 On 2/12/2018 at 3:14 AM, SatiricalHen said: Did you just cut the shape and then cover it and it just slides back there behind the b pillar plastic? Mine never had one and I’ve never seen one in person so I’m not 100% sure how they mount. Sent from my iPhone using Tapatalk Expand Mine also had no panel and like you I have never seen one. However looking at my B-Pillar plastic there are 2 notches on each side. So I cut out my Luan Board including 2 tabs for each side that coincided with the notches in the plastic. This is what I used to hold it in place. Link to comment Share on other sites More sharing options...
jbain Posted February 13, 2018 Author Share Posted February 13, 2018 On 2/12/2018 at 6:01 AM, natander2ksometime said: Love the white MJ! This is going to be super nice! I have a kinda strange and specific question about the rear bumper. How much material (front to back) is there in the section directly underneath the taillight? I'm wanting to put a tire carrier on something in the future and need to fit a 1.5" shaft directly under the tail light, with a bit of wiggle room front to back. I'd appreciate any info you could get me! Expand Thanks man, I still have the step bumper on my truck so I haven't installed this on yet. If you just want a static measurement then I can get that for you now. Link to comment Share on other sites More sharing options...
natander2ksometime Posted February 13, 2018 Share Posted February 13, 2018 On 2/13/2018 at 12:10 AM, jbain said: Thanks man, I still have the step bumper on my truck so I haven't installed this on yet. If you just want a static measurement then I can get that for you now. Expand Yeah, all I need is to know is if there's enough room for a 1.5" shaft somewhere between the tailgate and the outside edge of the bumper (left to right, if that makes sense). Thanks! Link to comment Share on other sites More sharing options...
SatiricalHen Posted February 13, 2018 Share Posted February 13, 2018 On 2/13/2018 at 12:08 AM, jbain said: Mine also had no panel and like you I have never seen one. However looking at my B-Pillar plastic there are 2 notches on each side. So I cut out my Luan Board including 2 tabs for each side that coincided with the notches in the plastic. This is what I used to hold it in place. Thanks for the replies, hopefully my little projects will turn out as well as yours! Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
jbain Posted February 17, 2018 Author Share Posted February 17, 2018 Thought I'd tear into the winch this morning and troubleshoot my power out not in issue. Ive never cracked open a solenoid cover before so I was a little overwhelmed at first but after peeling everything back it's pretty straightforward. Looks like 1 bad in and 1 intermittent out. Link to comment Share on other sites More sharing options...
jbain Posted February 17, 2018 Author Share Posted February 17, 2018 Time to get this 8.8 disassembled and cleaned up. I'm pretty excited to drop it off Monday for some fresh 4.88s and an ARB. Link to comment Share on other sites More sharing options...
jbain Posted February 18, 2018 Author Share Posted February 18, 2018 Brown truck dropped off my remaining pieces of the Comanches front links. I decided to stay with a 3 link so I'm upgrading the single upper from a 7/8th heim to a 1.25 Barnes Enduro. Link to comment Share on other sites More sharing options...
jbain Posted February 18, 2018 Author Share Posted February 18, 2018 2 days of grinding, cutting and sanding but it's finally ready for gears. Link to comment Share on other sites More sharing options...
jbain Posted February 18, 2018 Author Share Posted February 18, 2018 Took advance of the sun today to finally get the MJ bumpers primed. I had planned to coat them in a Duplicolor spray bedliner but it was way too heavy and splattered everywhere. What is everyone using for a textured look to their bumpers? Link to comment Share on other sites More sharing options...
SatiricalHen Posted February 19, 2018 Share Posted February 19, 2018 On 2/18/2018 at 9:02 PM, jbain said: Took advance of the sun today to finally get the MJ bumpers primed. I had planned to coat them in a Duplicolor spray bedliner but it was way too heavy and splattered everywhere. What is everyone using for a textured look to their bumpers? I love the rustoleum spray on Bedliner. Holds up pretty good. Did my sliders, 3 link, bumpers, trailer, and more with it. you can kind of see the texture in this picture, it’s still wet so that’s why it looks blotchy, but it’s good stuff. The regular stuff is better than the “professional” stuff in my opinion. Link to comment Share on other sites More sharing options...
jbain Posted February 20, 2018 Author Share Posted February 20, 2018 Right on, I appreciate the input. Link to comment Share on other sites More sharing options...
jbain Posted February 20, 2018 Author Share Posted February 20, 2018 Went up to Davey's Jeep today and picked up 5 factory Golden Eagle rims. Gonna.look sweet wrapped in 37 Pitbull Rockers. Link to comment Share on other sites More sharing options...
jbain Posted February 21, 2018 Author Share Posted February 21, 2018 Finished setting up the 8.8 with a fresh set of 4.88's and an ARB. Can't wait to get it under the truck. Link to comment Share on other sites More sharing options...
neohic Posted February 22, 2018 Share Posted February 22, 2018 Dang... those wheels. Very well played, sir. Link to comment Share on other sites More sharing options...
jbain Posted February 22, 2018 Author Share Posted February 22, 2018 On 2/22/2018 at 1:28 AM, neohic said: Dang... those wheels. Very well played, sir. Expand Thanks, I really do like them. But it doesn't look like I will be able to use the center caps. Link to comment Share on other sites More sharing options...
jbain Posted February 23, 2018 Author Share Posted February 23, 2018 Took advantage of the Pitbull Valentine's Day sale and scooped me up a set of 37 Rockers! I've always wanted a set of these tires. Link to comment Share on other sites More sharing options...
jbain Posted February 24, 2018 Author Share Posted February 24, 2018 Even though the Comanche floorpan is a little different than the XJ I took a chance on some WeatherTech floor mats. I'm happy to report that these fit nicely. Link to comment Share on other sites More sharing options...
