Smileybubby Posted October 8, 2017 Posted October 8, 2017 88 Comanche 4.0 jus died and won’t start.verified spark and fuel.swapped computer.before I swapped computer I leaned on the brake pedal and heard a clicking sound.ended up being the fan clutch.what the hell? changed computer,still no fire.fan clutch still engages when I push brake.unkooked computer completely and brake still engages ac fan clutch. please help
Smileybubby Posted October 8, 2017 Author Posted October 8, 2017 Just now, Strokermjcomanche said: How did you verify spark and fuel ? Just now, Strokermjcomanche said: How did you verify spark and fuel ? Pulled plug and cranked fuel rail Schroeder at 32psi not sending to cylinders,plugs dry and before you say cops,I already changed it
Strokermjcomanche Posted October 8, 2017 Posted October 8, 2017 So you aren't getting a signal to trigger the injectors to fire ? I know you said you changed the CPS , what voltage are you getting at the CPS plug when cranking ?
cruiser54 Posted October 9, 2017 Posted October 9, 2017 14 hours ago, Strokermjcomanche said: So you aren't getting a signal to trigger the injectors to fire ? I know you said you changed the CPS , what voltage are you getting at the CPS plug when cranking ? This^^. Here's how: http://cruiser54.com/?p=50
DirtyComanche Posted October 9, 2017 Posted October 9, 2017 I think you have a ground issue, or some wires melted together, based on the whole bizarre issue with your brake light switch engaging your aux fan. Might want to do a quick visual on your underhood harness, check your fuses and fusible links, and look at all the ground points.
carnuck Posted October 9, 2017 Posted October 9, 2017 Put a spoonful of fuel in the throttlebody after all else. Then if it doesn’t start you may have a burnt through ignition rotor. I would go after Cruiser54’s Renix maintenance first. Sent from my iPhone using Tapatalk
