Leaking On the Passenger Floorboard
So recently, ive been having water leak on to my passenger floorboard, and can't locate where its coming from. it doesnt smell like coolant by any means, so i don't think its the heater core. I'm thinking that water is coming in somewhere during rain, and it can only escape when i move th truck due to bumps and such. any ideas?
Two that I personally experienced are:
The radio antenna cable runs out of the cab behind the passenger side kick panel. It has a large rubber grommet that shrinks and falls out. So that is one place to check.
The other was the rear window.
Do a search on the forum for water in cab and I suspect you will find other discussions on this topic.
+1 for the radio cable
a deer hit my passenger side door 20 ish years ago. the deformed it enough so light can be seen between the door and cab in a couple places.  replacing the door seal with a later XJ seal helped, i also tucked some tubing behind the seal to push it out a little as well now the door seals, but still have a leak with the radio antenna.
I had my a/c drain tube plug up. Condensation from the evaporator would puddle and then pour out of the floor vents going around corners. There's a small rubber hose in the engine bay coming out of the heater box and pointing down. Popping that off dumped at least a gallon of water onto the ground. Pushed a screwdriver through the hose and put it back on, and it hasn't been an issue since.
I had this happen with an old 91 XJ
