Master7122 Posted August 26, 2017 Posted August 26, 2017 I might be buying a comanche with a 2.5l and just wanted to know what some common problems or things to look for are before getting it. It has 85k miles and is 2wd 5 speed
Pete M Posted August 26, 2017 Posted August 26, 2017 specifically about the 2.5 engine? or MJs in general?
Eagle Posted August 26, 2017 Posted August 26, 2017 What year? 1986 through 1990 were throttle body injected. 1991 and 1992 were multi-port injected. I believe it was '87 through '90 that the clutch used a combination release bearing/slave cylinder assembly, commonly referred to as the "internal" slave cylinder. They are a bit pricey, and replacement requires dropping the transmission and bell housing. Unfortunately, I don't know of any way to check one, other than to look for brake/clutch fluid dripping out of the bell housing. The timing chain in the 2.5L uses a tensioner. Those wear out, but 85k probably isn't enough for that to be an issue. Check the floors for rust -- both from underneath, and under the carpet/mat, if you can get a sense of what's going on from the topside. Check the frame rails under the bed in the area of the forward leaf spring hanger brackets.
Master7122 Posted August 26, 2017 Author Posted August 26, 2017 specifically about the 2.5 engine? or MJs in general? Just the 2.5, I've had 4 other Comanches with the 4.0 so I'm very familiar with them, just never had one with the 2.5
Master7122 Posted August 26, 2017 Author Posted August 26, 2017 And the year is 87' its rust free that's why I'm considering buying it
mnkyboy Posted August 26, 2017 Posted August 26, 2017 Nothing really big with the 4banger, normal maintenance stuff and it will go for a long time.
dasbulliwagen Posted August 28, 2017 Posted August 28, 2017 The 2.5 and 4.0 are closely related and share several parts. Any issues that are common to a 4.0 base engine are common to the 2.5 as well. The 2.5 doesnt have the 2 piece rear main seal though so if thats an issue the trans will need to be pulled to change it. Otherwise it will run forever just like a 4.0. Just remember to keep power expectations low, and you won't be too disappointed.
