My newest addiction, 80 CJ5
Now that the Jeep is fuel injected I needed a check engine light. I will be using this as my check engine light. I needed a way to let other people know what that glowing red ring means.
I decided to rip apart my new fan switch and make something different.
I drew this up on Microsoft Paint, attached it to a Word Doc, adjusted the size until I liked it, printed it and then I laminated it.
I then trimmed it to fit into the fan switch housing.
I also replaced the bulbs with blue LEDs.
Not bad at all. It puts a unique spin on a boring check engine light!
I spent the last two days redoing my dash. A prior owner butchered it!
Those three gauges are not supposed to be there.
I removed the whole dash panel.
Then cut out a square and welded new metal in. This is my first time welding sheet metal. I learned a lot.
I then stripped, painted and installed all my new parts.
I installed new gauges, lights, face plate and speakers. The gauge cluster is from Intellitronix and it is awesome!
It was a ton of work but we'll worth it.
I've done similar work on both my 67 Cj5 and 83 CJ7.  Looks great, big improvement!  I like the "retains the factory layout but with upgraded components" approach.  One of my biggest pet peeves for a CJ or Wrangler, is stray wires hanging from beneath the dash.  It screams "POS", and a previous owner who lacks attention to detail, making one wonder "what else did he shortcut?"
I got the CJ running pretty good so I took it out into the desert for a shake down run. It performed beautifully! This this is a beast off road. Just point the wheels and she'll eat!
That is until you blow a power steering o ring and high tail it back to the house and things go from bad to worse.
Lost a front wheel at 40 mph. Thank God I was out in the desert and not on the highway. All four wheels had worked loose. I ordered new lugs with a longer shank so hopefully this doesn't happen again.
With the wheels coming off and this thing only having a stock roll bar I started looking for windshield bars or a better cage. Just so happens the guy I bought my EFI setup hit me up and asked me if I wanted to buy his old cage and sliders.
We struck a deal for $200! Well, ok, I guess!
  • 1 month later...
I got the cage set in the CJ and it looked great!
Unfortunately my top would not fit right. So I fixed that.
Now my top fits like it should.
In the process of fighting with the cage I shattered the windshield. It was shot and it allowed me to see that the windshield frame was completely rusted out.
I also found out this was originally a real Renegade. I just threw the sticker on the hood because I liked it.
