Vehicle: 1991 Jeep Comanche Pioneer 4x4 LWB
VIN: 1J7FJ36S2ML537178
Engine: 4.0L HO (Chrysler Electronics)
Transmission: AX-4
Transfer Case: NP-231J
Front Axel: Dana 30 3.07 Gears
Rear Axel: Dana 35 3.07 Gears
Wheelbase: Long Wheel Base / Long Bed
Build Date:
Current Mileage:
Current Location: Southern Maryland
Status: Currently my daily drive with plans to become a camping vehicle in addition.
Notes: Has a window visor, sliding rear glass, and small pull bar with two (2) round KC lights. Exterior color is red with three square strips down the side with Pioneer at the rear. The inside is gray cloth with a bench seat notched around the floor shift.
Current owner: Me, Vakarian
History: Bought it from a older gentleman above Baltimore who used it to get sticks out of his yard. He was technically the third owner but the second owner just bought it to sell. I bought it with everything working only needing to replace the gas tank after getting it home. Has a few rust stops that need to be taken care of. A build thread will be following shortly as I was given parts to begin a lift for it.
  • 1 year later...
*C1 TRIM STYLE C1 - CLOTH && VINYL BENCH SEAT
-SA CHARCOAL
133 Zone 33-Philadelphia
1AA U.S. Dealer Retail
3V3 Customer Preferred Discount
ADL Skid Plate Group
ALN Body Color Bumper Group
APA Monotone Paint
ARL 300 Premium Group
BAP 75 Amp Alternator
BCX Nickel Metal Hydride Battery
BGA Power Front Disc/Rear Drum Brakes
CBA Straight Back Bench Seat
CKA Carpets - Floor and Cargo Area
CUM Mini Floor Console
DBB All Manual Transmissions
DDQ 5-Speed Manual Transmission
DHN Command-Trac Part Time 4WD System
DJH 230MM Front Axle
DMM 3.07 Rear Axle Ratio
DRJ 175MM Rear Axle
ERH 4.0L I6 Power Tech Engine
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEH Fixed Door Vent Glass
GFD Rear Sliding Window
GRZ Left Remote Mirror
GSZ Right Remote Control Mirror
GTZ Manual Remote Mirrors
HCD Do Not Use - See HCA
JAY DO NOT USE - See JP, KA classes
JCA 85 MPH Primary Speedometer
JGB Digital Clock
JHA Var Intermittent Windshield Wipers
JJA Cigar Lighter
K27 Do Not Use
K2B STRIPE/BADGE/MOLDING/COLOR
K3R STRIPE/BADGE/MOLDING/COLOR
KKS STRIPE/BADGE/MOLDING/COLOR
KWS STRIPE/BADGE/MOLDING/COLOR
LAP Shift Indicator Warning Lamp
LBC Glove Box Lamp
LMA Halogen Headlamps
MB1 Black Front Bumper
MBJ Black Powder Coated Front Bumper
MDA Front License Plate Bracket
MFF Black Grille
MHA Black Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMK Lower Grille Surround-Painted Silver
NAA Federal Emissions
NBK EVAP Control System
NF5 Fuel Tank - 23 Gallon
PE4 COLORADO RED CC PRI PNT - HE4
QE4 COLORADO RED CC SEC PNT - HE4
RAA All Radio Equipped Vehicles
RAF AM/FM Cassette Radio
RCD 4 Speakers
SBA Power Rack and Pinion Steering
SCE Alcantara Wrap Steering Wheel
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
TBB Full Size Spare Tire
TBM Tire Carrier Winch
TMW P265/60r18 BSW A/S All Terrain Tires
TZH Michelin Brand Tires
WJN 15" Aluminum Wheels
WLZ All Aluminum Wheels
XBS Pickup Box
YAA Build To U.S. Mkt. Specifications
YGE 5 Additional Gallons of Gas
Z01 Rear Spring Group I
Z5A GVW/Payload Rating
Z66 Left Front Group XV
Body Model JL62
Build Date 10/10/90
  • 1 year later...
