ComancheCrusher9800 Posted June 9, 2017 Share Posted June 9, 2017 I have a 2.5l 1987 jeep Comanche long wheel base. When I start it it will run fine. It doesn't have a certain pattern to it but it will start bucking at low speeds and sometimes stalls and makes it look like I can't drive a standard. At high speeds when I press the gas down it will loose rpms and have less power. When I turn it off and press the gas a couple of times then turn it back on it will usually do good for a couple more miles. At first my problen was the plug wires popping off so I replaced the spark plugs and wires. I replaced the coil pack also. The distributer cap it not cracked. Sometimes it will drive for miles and be fine and sometimes it will be right away. I've already tried looking for this on this forum but I can't find anything that helps Link to comment Share on other sites More sharing options...
omega_rugal Posted June 9, 2017 Share Posted June 9, 2017 check TPS, MAP... your problem is the fuel system, leave the ignition alone Link to comment Share on other sites More sharing options...
ComancheCrusher9800 Posted June 9, 2017 Author Share Posted June 9, 2017 Has a new map sensor and the problem was the ignition at first I can tell you straight up it was because you could see spark coming from the coil to a ground and the plug wires were popping off Link to comment Share on other sites More sharing options...
omega_rugal Posted June 9, 2017 Share Posted June 9, 2017 losing power when pressing the gas pedal has nothing to do with the ignition, you are giving it air but not enough fuel, the ecu uses the throttle position + manifold pressure and to some degree the coolant and air temp to calculate how much fuel to deliver in that particular condition unless it`s some weird domino effect caused by several failing sensors, i would start there, TPS and MAP... Link to comment Share on other sites More sharing options...
cruiser54 Posted June 9, 2017 Share Posted June 9, 2017 Is the ground strap from the firewall to the head intact? If so, still remove it at the firewall and scrape to bare metal and reinstall. Link to comment Share on other sites More sharing options...
ComancheCrusher9800 Posted June 13, 2017 Author Share Posted June 13, 2017 So I replaced the throttle position sensor and it fixed it completely for a few days and now it started again. It doesn't do it as badly but it still will do it after about 10 minutes of driving. What now? Link to comment Share on other sites More sharing options...
ComancheCrusher9800 Posted June 13, 2017 Author Share Posted June 13, 2017 And it already has a brand new map sensor i just put on it about a week ago Link to comment Share on other sites More sharing options...
cruiser54 Posted June 14, 2017 Share Posted June 14, 2017 And it already has a brand new map sensor i just put on it about a week ago Post 5? Link to comment Share on other sites More sharing options...
ComancheCrusher9800 Posted June 14, 2017 Author Share Posted June 14, 2017 What do you mean post 5? Link to comment Share on other sites More sharing options...
ComancheCrusher9800 Posted June 14, 2017 Author Share Posted June 14, 2017 And I did your c101 elimination this morning I couldn't find the ground slice coming from the map sensor though only the one from the tps and I didn't want to cut too much more tape off the wiring Link to comment Share on other sites More sharing options...
ComancheCrusher9800 Posted June 14, 2017 Author Share Posted June 14, 2017 Are talking abut your #5 tup the sensor ground? It's raining right now and I got work in an hour but I'll check it out in the morning and go from there Link to comment Share on other sites More sharing options...
ComancheCrusher9800 Posted June 14, 2017 Author Share Posted June 14, 2017 I also scraped the ground from the head to the firewall like you said Link to comment Share on other sites More sharing options...
cruiser54 Posted June 14, 2017 Share Posted June 14, 2017 What do you mean post 5? Is the ground strap from the firewall to the head intact? If so, still remove it at the firewall and scrape to bare metal and reinstall. Link to comment Share on other sites More sharing options...
ComancheCrusher9800 Posted June 15, 2017 Author Share Posted June 15, 2017 I did that when you told me to the other day and yeah it's intact I'm gonna check the ground to the dip stick in the morning Link to comment Share on other sites More sharing options...
cruiser54 Posted June 15, 2017 Share Posted June 15, 2017 I did that when you told me to the other day and yeah it's intact I'm gonna check the ground to the dip stick in the morning great. Just making sure. Link to comment Share on other sites More sharing options...
ComancheCrusher9800 Posted June 15, 2017 Author Share Posted June 15, 2017 That didn't work and I even made new grounds Link to comment Share on other sites More sharing options...
ComancheCrusher9800 Posted June 15, 2017 Author Share Posted June 15, 2017 I'm about to put the carbureter on it Link to comment Share on other sites More sharing options...
fiatslug87 Posted June 15, 2017 Share Posted June 15, 2017 Have you checked the EGR system? I'm assuming a 2.5L in '87 has it. Link to comment Share on other sites More sharing options...
Eagle Posted June 16, 2017 Share Posted June 16, 2017 Comanchecrusher has a new thread going, on carburetors, so this thread is closed. Otherwise we'll all be talking in circles. Link to comment Share on other sites More sharing options...
