johnj92131 Posted April 23, 2017 Share Posted April 23, 2017 I am having a problem finding a part number and a diagram in the parts book for the the AX15 Torque arm bracket. I bolts on to the bottom of the AX15 transmission, then the transmission mount gets bolted on, and lastly the transmission cross member. I need this for the AX15 going in my TDI diesel 86 Comanche. Any pointers, help is appreciated. Think this is what I need - first image on this page: https://www.google.com/search?sourceid=chrome-psyapi2&ion=1&espv=2&ie=UTF-8&q=torque%20arm%20bracket%20cherokee%20xj&oq=torque%20arm%20bracket%20cherokee%20xj&aqs=chrome..69i57.18196j0j8 Link to comment Share on other sites More sharing options...
Jeep Driver Posted April 23, 2017 Share Posted April 23, 2017 Making your own..........or Brown Dog style..........motor mounts will render the 'torque arm' meaningless. Just say'n. The mount plate will be a JY item. Link to comment Share on other sites More sharing options...
HOrnbrod Posted April 23, 2017 Share Posted April 23, 2017 I think it's #24 or #25 below you are looking for.......... Link to comment Share on other sites More sharing options...
johnj92131 Posted April 23, 2017 Author Share Posted April 23, 2017 Thanks Don. #25 is what I need. Never would have thought to look in the section for "Engine Mounting" for the transmission bracket. But I got nothing looking in the "Transmission" section. EDIT: Anybody have one for sale??? Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted April 23, 2017 Share Posted April 23, 2017 I think I have one John , i pulled an ax15 from a 98Xj and I think it's still bolted to it . Once I get home from cutting my moms grass I'll take a look . I know I have one from a nv3550 ( I believe it bolts in the same way) the only difference is where the exhaust goes through is a round steel rod VS the "sad" face bracket lol. Link to comment Share on other sites More sharing options...
HOrnbrod Posted April 23, 2017 Share Posted April 23, 2017 Thanks Don. #25 is what I need. Never would have thought to look in the section for "Engine Mounting" for the transmission bracket. But I got nothing looking in the "Transmission" section. I stumbled on it when I was looking for a replacement mount for my AW4. You gotta wonder what the morons were thinking when they organized the factory parts manuals. :nuts: Link to comment Share on other sites More sharing options...
DirtyComanche Posted April 23, 2017 Share Posted April 23, 2017 I made mine out of an AW4 mount because I didn't have an AX-15 handy... If you're stuck, it is a fairly easy piece to make. To do it over I would make a different mount for the exhaust anyways, because the previously mentioned 'sad face' one isn't the best for what I'm normally doing. Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted April 23, 2017 Share Posted April 23, 2017 I have it John , but in 98 it uses a rod for the exhaust mount and the piece you're looking for is also made different . As a whole assembly it should work . I took pics of it but photobucket sucks and is down , I can email you photos if you'd like Link to comment Share on other sites More sharing options...
johnj92131 Posted April 23, 2017 Author Share Posted April 23, 2017 I have it John , but in 98 it uses a rod for the exhaust mount and the piece you're looking for is also made different . As a whole assembly it should work . I took pics of it but photobucket sucks and is down , I can email you photos if you'd like Great! johnj92131@yahoo.com Whitbread has to build a custom downpipe for the TDI engine anyway - everything from the CAT forward. Use imgur.com for pictures!!! Way faster, Way easier than photobucket. Pete suggested it and I loved it. Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted April 23, 2017 Share Posted April 23, 2017 Sent you an email ..... Link to comment Share on other sites More sharing options...
johnj92131 Posted April 23, 2017 Author Share Posted April 23, 2017 Sent you an email ..... Replied. I will take the AX15 bracket. That is what we need. Let me know how much to send! Link to comment Share on other sites More sharing options...
johnj92131 Posted April 24, 2017 Author Share Posted April 24, 2017 For anyone else with this issue, here are some pictures. First, AX-15 transmission mounting points on the bottom of transmission case: Original AX-5 bracket - note only 3 mount holes and bracket not big enough to fit the AX-15 case holes. EDIT: AX-5 bracket has 4 holes not 3 as I said above. Missed the 4th hole at the bottom because of grease and dark background! Correct AX-15 bracket on top. NV3550 bracket on the bottom. Link to comment Share on other sites More sharing options...
