Id like to swap a ford 9" under my 87 is it a great choice ?! don't want to spend on jks 44 and not planning puttin some 48s tire so dana 60 isnt really worth it... pain in the @$$ job or preaty easy ?
60.00 1967 Cougar
60.00 1958-1960 Edsel
61.00 1964-1971 Ford Full Size
61.00 1949-1951 Mercury
61.25 1957-1972 Ford F-100 Pickup
61.25 1960-1964 Ford Full Size
61.25 1971-1973 Mustang
61.25 1967-1973 Torino, Ranchero, Fairlane
http://carnut.com/specs/rear.html
It is a great choice.......but............spendy.
I believe the measurements above are WMS to WMS.........ought to give you a place to start looking.
Isn't the front diff on the passenger side on a Chief?
Yes but i plan to maybe cut it and switch it... i can't buy only the rear one the guy is givin me both so was thinkin of the option
what is the plan for the truck?
Street/trail truck.... max 37s tires spartan locker in the back detroit true track in the front 6-8" lift kit long arm 4L stroker thats about it
Didnt buy the 44 finally i found a ford f100 9" for free ill keep my d30 hd in the front hdo you have any tips for me ill start the swap soon
Unfortunately, you bought a less desirable 9". If it did in fact come from an F100, it has 28 spline shafts and small bearing ends iirc. Been a while since I really dived into it but that sounds right.
The F150s had 31 spline shafts and large bearings ends.
Sent from my LGLS992 using Tapatalk
Just saw that it was free, but still, it is probably not worth swapping it in.
A Ford 8.8 would probably suit you better.
Easy job to do, the small bearing 28 spline isn't terrible. Worst comes to worst, bring it to a speed/machine shop and have them weld torino or big bearing ends on.
