Dana 35 fluid
If it is your DD, and you are unable to pull the cover and drain the fluid before buying new stuff, just buy the one with friction modifier and put it in.  Nothing bad will happen.
If you are able to pull the cover to inspect it first, then compare what you are seeing to pics on the ol' Google machine, and see what type of carrier you have, and purchase accordingly.
