Goose_XJ88 Posted February 8, 2017 Share Posted February 8, 2017 Looking for the factory rollbar mount that goes to the "frame". Mine is a SWB so not sure if that makes a difference. Thanks. Link to comment Share on other sites More sharing options...
HOrnbrod Posted February 8, 2017 Share Posted February 8, 2017 Good job on your ASCII MJ. :cheers: Link to comment Share on other sites More sharing options...
Goose_XJ88 Posted February 8, 2017 Author Share Posted February 8, 2017 Thanks. I worked for a while to change it up from yours and I actually like it more than before. Link to comment Share on other sites More sharing options...
Goose_XJ88 Posted February 24, 2017 Author Share Posted February 24, 2017 Just for clarification, this is what I am looking for. On 11/2/2013 at 4:54 AM, skidoo_j said: Factory Roll bar tie in brackets:Pictures of the under bed brackets that a member emailed me along time ago not sure if they're posted anywhere else. found owner of pictures, jimoshel: link to original post of brackets with rubbers too Link to comment Share on other sites More sharing options...
Goose_XJ88 Posted March 28, 2017 Author Share Posted March 28, 2017 bump. still looking Link to comment Share on other sites More sharing options...
Goose_XJ88 Posted May 12, 2017 Author Share Posted May 12, 2017 Bump Link to comment Share on other sites More sharing options...
Bonkers Posted May 12, 2017 Share Posted May 12, 2017 Took over a year to find my last set, My suggestion: check local junkyards for 86's. Alot of those had rollbars torn out, but the owner wouldnt even bother with the brackets. Its a long shot at best, but if youre in a hurry... ... Link to comment Share on other sites More sharing options...
Goose_XJ88 Posted May 13, 2017 Author Share Posted May 13, 2017 Not really in a hurry per say but I do want to install my roll bar. I appreciate the suggestion tho. That is really helpful info. Link to comment Share on other sites More sharing options...
Goose_XJ88 Posted July 13, 2017 Author Share Posted July 13, 2017 Bump Link to comment Share on other sites More sharing options...
Goose_XJ88 Posted August 7, 2017 Author Share Posted August 7, 2017 To the top Link to comment Share on other sites More sharing options...
Pete M Posted August 7, 2017 Share Posted August 7, 2017 just a heads up, the extra mount really isn't the most necessary thing in the world. the bar isn't going to save your head in a rollover so simply popping holes through the bed is sufficient to hold up some lights. :thumbsup: but I always admire the hunt for factory-spec. :bowdown: . :MJ 1: . Link to comment Share on other sites More sharing options...
Goose_XJ88 Posted August 11, 2017 Author Share Posted August 11, 2017 That would be awesome. I don't have the time to fabricate. I know the roll bar won't help in a rollover but my truck has the holes for a factory piece. I just want it to mount like it did from the factory bc it would be more secure for the spare mount I plan on building off of the factory bar. Link to comment Share on other sites More sharing options...
budwisr Posted August 11, 2017 Share Posted August 11, 2017 On 8/10/2017 at 3:51 AM, saveevryjp1998 said: Ive got some and 2 lwb bars and 1 swb. I need to make some I only have the 1 pair of brackets. People leave em cause its a pita Ive learned. Soon as I make em ill sell em for cost there isnt much to it. I'm interested in a set for a LWB. :cheers: Link to comment Share on other sites More sharing options...
kryptronic Posted August 11, 2017 Share Posted August 11, 2017 I'm also looking into fabbing a set, or having a set fabbed for my SWB. I've got pics of all pieces and FSM diagrams but no real measurements or CAD data appears to be available. I'd like to duplicate the factory mounts as closely as possible. Count me as interested. Link to comment Share on other sites More sharing options...
Bonkers Posted August 12, 2017 Share Posted August 12, 2017 I don't think the mounts are different between beds since they mount in the same place on both styles. Not a news flash, but i don't want someone passing up on a "swb" set thinking they won't work on a "lwb"... Link to comment Share on other sites More sharing options...
kryptronic Posted August 12, 2017 Share Posted August 12, 2017 On 8/12/2017 at 8:14 AM, Bonkers said: I don't think the mounts are different between beds since they mount in the same place on both styles. Not a news flash, but i don't want someone passing up on a "swb" set thinking they won't work on a "lwb"... Thanks Bonks. Correct. Mounts are the same for SWB and LWB, the bars thenselves are the only difference. What can we do to get this moving? Link to comment Share on other sites More sharing options...
krustyballer16 Posted August 12, 2017 Share Posted August 12, 2017 I've built 2 sets. They're not hard at all. But I didn't use them this last time I put my rollbar back in. Not needed. I used rear backing plates inside the wheel well though, since they were super easy to install. Sent from my HTC One M9 using Tapatalk Link to comment Share on other sites More sharing options...
